Dyna 2000p tach
Old Apr 28, 2014 | 02:45 PM
HGM's Avatar
HGM
Default Dyna 2000p tach
Quick question as I sit at work.. After buttoning my project up last night, the tach reads about half normal. I just installed the Dyna module on my Electra Glide, had to wire it all, not just plug and play.. Wondering if anyone had been there and knows what I need to check first..
Thanks,
Old Apr 28, 2014 | 05:18 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Is your tach set up for singe fire or dual fire?
Old Apr 28, 2014 | 05:44 PM
Owtlaw's Avatar
Owtlaw
Yepper. I'd bet on a single fire ignition and a tach set for dual fire. Either a setting or use a tach adaptor. Or multiply.
Old Apr 28, 2014 | 06:37 PM
HGM's Avatar
HGM
Sure sounds reasonable.. I just got home and double checked, I did have it set to single fire. Switched it to dual, didn't notice much change, but I didn't get to ride it to verify. Seems like idle is still about 600 on either.. Just during my ride yesterday, what would normally be 3000 was reading about 1500.. Got a tornado warning right now, so I'll have to wait to do more.. Don't care for the hail and wind, guess I'm fair weathered.... Since this was born an EFI bike, wouldn't the tach be calibrated for single fire anyway??
Old Apr 28, 2014 | 07:01 PM
johnjzjz's Avatar
johnjzjz
harley ignitions are one pulse for the tach - some tachs are 1 or 2 pulse they have a duel sender and a thin brown wire needs to be cut if you are not runing a stock harley tach
its always at the exit if the tach wires pull the covering back and look for it if its not an OEM harley tach
Old Apr 28, 2014 | 08:26 PM
HGM's Avatar
HGM
I got some clear weather and played with it a bit.. Took it for a ride in single, tach about half, all speeds(didn't seem to do that earlier, might need Key off input to switch).. Then I switched it to dual and got normal RPM.. Guess that was it, thanks for the input guys!! By the way, I also switched it to curve #1 while I was at it, seems to like that too, all I need is more switches to dick with!!
Old Apr 28, 2014 | 10:22 PM
Maxdog2's Avatar
Maxdog2
I am about to go through the same process on the switches, not in front of the directions, but seems #1 is the most advanced. If memory serves me you start with #2 and if all seems good to try #1. Thanks for sharing.
Old Apr 29, 2014 | 05:05 AM
HGM's Avatar
HGM
Yea, I followed those instructions and while impressed with the way the bike ran since the major rebuild, #1 made a pretty decent difference. The curve looks to be much more aggressive, ramping up much earlier in the chart I saw.... Really need to ride it a bit more to make sure its the way I'll keep it though.. In fact, I followed their time it by the LED procedure, I may throw a timing light on it to make sure its advanced enough.. Being new to it, I'm a bit skeptical of its accuracy, but its a great way to begin the process!
Old Apr 29, 2014 | 07:41 AM
Maxdog2's Avatar
Maxdog2
Thanks, and keep us posted on the accuracy. I am planning to do the same.
rydahog
General Topics/Tech Tips
Jun 24, 2017 09:30 PM
blink1968
Jul 17, 2011 01:08 AM
t150vej
EVO
Jan 14, 2009 05:12 PM
solitaryman54
Ironhead
Apr 2, 2007 01:54 AM
sporty2003
Feb 12, 2007 03:54 PM
