Screaming eagle top end gasket kit
Old May 7, 2014 | 09:39 AM
01fxdxt's Avatar
01fxdxt
Default Screaming eagle top end gasket kit
Anyone have experience with this kit?Thoughts ,yay or nay?
Old May 7, 2014 | 07:37 PM
johnjzjz's Avatar
johnjzjz
most have found cometic gaskets in the metal material MLS is the best available in todays riding -
harley will call SE gaskets the best ever made - sure if you like a flathead ford your in
look up cometic they are not cheap - but its a once not well they are leaking again
Old May 7, 2014 | 08:00 PM
HarDlife's Avatar
HarDlife
^^^right there.
Cometic or pathetic? Choose wisely.
Old May 7, 2014 | 08:13 PM
traildog's Avatar
traildog
Originally Posted by HarDlife
^^^right there.
What the..........................
Old May 7, 2014 | 08:16 PM
Tee&Vee's Avatar
Tee&Vee
James on the Softail are just as good as your precious Cometic set. They are 2 years old and no signs of a leak. That being said the '98 road glide will be using a box of Cometics. :-)
Old May 7, 2014 | 08:21 PM
HarDlife's Avatar
HarDlife
Ye flameth what thou doth not understandeth, foolish naive!!
Old May 7, 2014 | 08:25 PM
Beemervet's Avatar
Beemervet
With Screaming Eagle gaskets you get an extra 5 hp.
Old May 7, 2014 | 08:27 PM
johnjzjz's Avatar
johnjzjz
james is a 10 year old teckno - come on be poster boy for your statement ( James on the Softail are just as good as your precious Cometic set )
you cant give up on them in the middle of your no leak RUN
hellooo ( They are 2 years old and no signs of a leak ) you are bailing on james super quality stuff
REALLY
Old May 8, 2014 | 06:27 AM
rapid49's Avatar
rapid49
I like Cometic Gaskets the best.
Old May 8, 2014 | 04:41 PM
Spanners39's Avatar
Spanners39
I have used James since forever and never had a problem. The only time I ever had issues with aftermarket gaskets was when I used the ones that came with a Taiwanese Sporty 883-1200 big bore kit...they lasted 3 days!!
