New issue. Never ends...
Old May 31, 2014 | 07:32 PM
  #41
Kabear's Avatar
Kabear
Originally Posted by Spanners39
I wouldn't ignore it, happened on my Wide Glide and it was only and hour to fix it...what kinda person would ignore something like that?
A person that lives in an area where one can ride 12mo. out the year. :-)
Old Jun 26, 2014 | 06:12 PM
  #42
Neekorelli's Avatar
Neekorelli
To bad the video doesn't work anymore. I think I have the same issue. Think.
Old Jun 26, 2014 | 06:14 PM
  #43
br549A1's Avatar
br549A1
. Post one I'll tell you if it sounds like mine did. It definitely didn't sound like it was coming from the crossover until I put the stethoscope on it. I never would have even checked there
Old Jun 26, 2014 | 07:07 PM
  #44
johnjzjz's Avatar
johnjzjz
stop riding it -
remove the clutch cable cover on the right side of the trans -
TOB - throw out bearing can and does make jingle noizes when its falling apart
BEARINGS -- the stay bearing in the trans cable cover attachment plate - when bad makes jingle noizes - pull on it ( vise grip on the bearing nut ) see if they move in and out if so they are shot - THIS is also the possable cause of the 3rd gear issue ( if the main shaft is floating around than any number of things can make noize and not ingage correctly )
engine timing is an exact adjustment an off hand guess is going to un do the engine in any number of ways - stop complaining if your not going to do this as it is to be done
Old Jun 26, 2014 | 07:17 PM
  #45
br549A1's Avatar
br549A1
Originally Posted by johnjzjz
stop riding it - remove the clutch cable cover on the right side of the trans - TOB - throw out bearing can and does make jingle noizes when its falling apart BEARINGS -- the stay bearing in the trans cable cover attachment plate - when bad makes jingle noizes - pull on it ( vise grip on the bearing nut ) see if they move in and out if so they are shot - THIS is also the possable cause of the 3rd gear issue ( if the main shaft is floating around than any number of things can make noize and not ingage correctly ) engine timing is an exact adjustment an off hand guess is going to un do the engine in any number of ways - stop complaining if your not going to do this as it is to be done
Are you telling me to stop complaining? I was just helping someone else, I know why mine is jingling
Old Jun 26, 2014 | 07:20 PM
  #46
oppirs's Avatar
oppirs
Smile
Simple I forced the inner pipe that broke with a screw. No rattle! Not to code but who cares?
TeeJayEe
Jun 15, 2024 09:33 AM
worstdayever
Carburetor Related
Sep 26, 2018 09:18 AM
jeeper0122
Aug 3, 2017 01:13 PM
jcsurf
Carburetor Related
Apr 30, 2015 05:27 AM
lmarklar
Sep 14, 2011 03:11 AM
