Blinker fluid
Old Jun 1, 2014 | 08:15 PM
  #31
300Slim's Avatar
300Slim
I spilled Horn oil in my Blinker fluid. It pisses cagers off.
Old Jun 1, 2014 | 09:58 PM
  #32
92Fatty's Avatar
92Fatty
Caution: Current thread will induce uncontrollable laughing.
Old Jun 1, 2014 | 10:41 PM
  #33
nanaimohd's Avatar
nanaimohd
If I changed my blinker fluid do I have to rotate my brake rotors and what pattern if I have 3 of them ??
Old Jun 1, 2014 | 11:07 PM
  #34
HarDlife's Avatar
HarDlife
Yes. Rotate in a clockwise pattern. RF goes to rear, rear goes to LF, LF goes to RF. Make sure to lube the rotors while they are off (unless you have done the bearing upgrade I previously mentioned).
Old Jun 1, 2014 | 11:29 PM
  #35
metalsoul's Avatar
metalsoul
Originally Posted by Spanners39
Yes but make sure you use Olive oil.
And don't forget to Armor-oil up ur tires nice and shinney too while ur at it so they look so...Sllllllliiiiick!
Old Jun 2, 2014 | 06:34 AM
  #36
junglejoe's Avatar
junglejoe
Just poured coffee in the tank, should make it go faster now!
Old Jun 2, 2014 | 08:11 AM
  #37
CISO1969's Avatar
CISO1969
No...no...no. The best oil to use is 710 oil. After moving the left -handed smoke shifter to the right, access the muffler bearing and lift it with either a special tool that the dealer sells for $750 or get the same thing at Harbor Freight called a "Sky hook". Once lifted, access the right handed anti fume cap and loosen until snug. Pour in the oil as you drain it.
That should solve the issue. YMMV
Lee
Old Jun 2, 2014 | 11:51 AM
  #38
traildog's Avatar
traildog
Originally Posted by HarDlife
Fixed it for ya!!
You callin me a butthole? butthole?
Old Jun 2, 2014 | 11:55 AM
  #39
scrapper's Avatar
scrapper
Default blinker fluid
Has anyone tried the new glass hammer, im sure its a lot lighter than your standard hammer.
Old Jun 2, 2014 | 12:40 PM
  #40
jimbo285's Avatar
jimbo285
Originally Posted by traildog
SEAFOAM makes buttholes wonderful...........
Now it's fixed
