ev72 tight points in rotation
Old Jun 4, 2014 | 06:04 AM
Schex's Avatar
Schex
Old Jun 4, 2014 | 06:05 AM
Pinetop's Avatar
Pinetop
at zero last no advancement after purod are not moving vertically, same thing. I might be over cautious. steep ramps just feel less like a flow. could it be me
Old Jun 4, 2014 | 06:09 AM
Pinetop's Avatar
Pinetop
it is happening when intake on no.2 is closed not moving
Old Jun 4, 2014 | 06:19 AM
Pinetop's Avatar
Pinetop
dropped 1/4 tsp. oil in each cylinder much better on forward or correct motor rotation. the motor is still really tight from last overhaul only 6300 miles on the pistons and cylinders set at .0012 piston to cylinder clearances
Old Jun 4, 2014 | 06:46 AM
Pinetop's Avatar
Pinetop
I had HD assembly lube on cylinders but i guess at 72 degrees it was tight.
Old Jun 4, 2014 | 03:29 PM
Spanners39's Avatar
Spanners39
Originally Posted by texashillcountry
FFR= For F-cks Sake
FFS you mean......over here we have a WD40 equivalent called CRC which gets called CCR by all the old Hippies and Rockers (Creedence Clearwater Revival)
Old Jun 4, 2014 | 03:49 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yeah well spelling was never my forte.
Old Jun 4, 2014 | 03:56 PM
miacycles's Avatar
miacycles
What is the clearance between the inner lobe and the crankcase relief???
John
Old Jun 4, 2014 | 04:32 PM
Spanners39's Avatar
Spanners39
Yes, and you forgot the U in F#*K
Old Jun 4, 2014 | 04:52 PM
traildog's Avatar
traildog
YEA, can't even spell forty.......... Sheesh.......
