Properly Timing an Evo question
Old Aug 10, 2014 | 07:20 PM
  #101
Spanners39's Avatar
Spanners39
Originally Posted by kp877
Under full throttle it feels like the power drops off at 4500rpms. Pulls hard at 4000 then no juice 4500+
Found this on google. Looks like I must have picked the wrong module this one looks like it's less advanced than my stock p curve. Spanners was this the one you used or did I completely misread when I searched this.
Not sure, I get mine from a guy who used to race a Sporty and they come with a heap of different part numbers....some come from a Buells and have 883 on them!
A Sporty red lines at 6200rpm so you shouldn't experience any drop off in power with the module unless you have it timed or jetted wrong.
Old Aug 10, 2014 | 07:57 PM
  #102
br549A1's Avatar
br549A1
All of which is possible. What's marked on your module for a part number I'll see if I can figure it out. 4000 pulling hard, 4500 flat out of juice
Old Aug 10, 2014 | 09:45 PM
  #103
Spanners39's Avatar
Spanners39
I don't have an Evo any more, it got written off by a retarded redhead with an IQ of 6....so I can't tell you but regardless of which module you use from a Sporty it shouldn't go soft on you from 4500rpm.
Old Aug 10, 2014 | 10:13 PM
  #104
tmanbuckhunter's Avatar
tmanbuckhunter
Sounds like the stock cam to me... them things are anemic.
Old Aug 11, 2014 | 12:01 AM
  #105
Spanners39's Avatar
Spanners39
Stock cam will pull to 5300 rpm with no issues...as long as the bike is set up correctly.
Old Aug 11, 2014 | 05:14 AM
  #106
HGM's Avatar
HGM
Is the lack of power new since the module??
Old Aug 11, 2014 | 05:28 AM
  #107
br549A1's Avatar
br549A1
Going to have to get it on the highway this week. I don't Got WOT much but I though it pulled through 5. I have both modules so can swap plugs on the road. Ordered a jet kit too from cvp
Old Aug 18, 2014 | 05:29 AM
  #108
br549A1's Avatar
br549A1
Swapped the ignition plugs back to the stock P curve and installed the cvp kit getting rid of the dynojet main, emulsion and needle. Installed new plug wires. Seems to start easier. One carb fart coming off idle on a ride but no backfiring. Went WOT from a dead stop pulls to 4500 then flat. Odd, swear I pulled hard through redline before.
Old Aug 19, 2014 | 07:00 PM
  #109
br549A1's Avatar
br549A1
Learned some things about timing tonight. Apparently to time the bike with the module I have you have to set it at 1000-1400 rpms to 20 degrees advance then when it gets over 2000 at some point the module advances it fully. I had it set to 27 degrees at 1400 or less and the mark from when I bought it was set to 15 or so. I reset it to 20 degrees and it's dead on now from 1000-1500 rpms when it starts changing the curve. The manual must vary based on model year and ignition module curve used which is why I couldn't get it set with everyone's help it would never advance far enough unless I hit the correct max rpm/advance point.
Old Aug 25, 2023 | 05:20 PM
  #110
otheym's Avatar
otheym
The vendor says it only fits 1970 to 1978. Could this be installed on a later model. Mine is a 1989 FXR.
Bill M.
