Properly Timing an Evo question
Old Jun 6, 2014 | 07:48 PM
Spanners39's Avatar
Spanners39
BTW, I have timed Harleys without the clear pug and its a huge mess! you can taste motor oil for days!!! I have Dyna and Sporty clear plugs now.
Old Jun 7, 2014 | 07:33 AM
Maxdog2's Avatar
Maxdog2
Originally Posted by Spanners39
Don't touch VOES, set to single dot at full advance which is either 2500 rpm or if no tacho just rev it until it stops advancing...this is the correct way to do it according to the manufacturer so I wouldn't **** about doing it any other way, no matter how convincing the argument.
I set mine last fall to the rpm specified in the manual, lower than 2500 and found when the Dyna 2000i was installed the timing was still a little off. If I would have set as you recommend I bet it would have been spot on. The correct timing has made a big difference. Setting the timing last fall helped, but getting it correct makes for a new bike. The bike starts easy, has more power, and seems smoother.
Old Jun 7, 2014 | 09:10 AM
br549A1's Avatar
br549A1
Double checked the manual this morning, says to set at idle to the double dot, 20 degrees. Seems like everyone does the single and gets the rpms past VOES.
Old Jun 7, 2014 | 02:09 PM
aces&8s's Avatar
aces&8s
My book say's the double dot is international timing. So single dot is what you want at 35*.
Old Jun 7, 2014 | 02:20 PM
aces&8s's Avatar
aces&8s
Originally Posted by D_gyver
you can do it that way but you will be a few degrees off your timing mark is 35 deg. but your ign. is only set to 33 default so when you start your bike your going to be two degrees advanced that why I use TDC and a Dial back timing light
or program the 2000i curve one to max advance at 35 degrees then the way you mentioned will work perfect
I retimed it this morning by Dynatek standards just to see the difference. Mostly only 1or 2 degrees difference if that from what brother Dgyver did. Might even be slightly more advanced than I need now. Because it trys to ping when real hot out the hole. I went to next bigger intermediate jet [295] to tame it.
If not Ill have to retard 1-2*. Other than out the hole, no ping and it aint never ran better. Quick, Quick...
Old Jun 7, 2014 | 02:45 PM
br549A1's Avatar
br549A1
I painted the dot. Been at it for 30 minutes. Can't get it. What a project. I know this is suppose to be easy and I can't find the dot when it's running
Old Jun 7, 2014 | 03:06 PM
br549A1's Avatar
br549A1
Well. I gave up. I tried timing it to where or was marked, no good, retarded it a little and ran like **** so went back a little. Couldn't see it advanced a little more and it ran better still couldn't see dot. A little more and ran out of adjustment it's advanced as far as it will go now, but it's also running better at idle and holding at 2500 rpms when trying to see the dot, I still can't see the damn thing so I don't know what the plan is now. It's a snap on timing light with adjustments from 0 to 60 and I turned it all the way down. Snapon mt241a
Old Jun 7, 2014 | 03:24 PM
aces&8s's Avatar
aces&8s
OK. Set it back to the original setting. Turn clockwise 16th of an inch at a time [2* or 2 hairs] until it comes up in the window. Very small movement and it will go out of the window completely. You have to snug the screw dn each time to grd the ignition or it wont work. I did mine by myself several times here lately, its not hard to see the dot when its in the window. about 1800 rpm works fine. I also use a big fan on high set right up on the engine to cool it when running.
Old Jun 7, 2014 | 04:00 PM
Spanners39's Avatar
Spanners39
Double dot is CA and places like Switzerland that have very strict emission and noise laws...single dot is the only one to use in the real world.
Spanners39's Avatar
Spanners39
Are you timing the front jug?
