Dyna death wobble...
Old Jun 17, 2014 | 08:28 AM
zimm's Avatar
zimm
Default Dyna death wobble...
Since I did the suspension on my '96 dyna, she's been very twitchy at highway speeds. A good bump just about sends the bars into a tank slapper. I think it has to do with running 13" shocks on the rear and the fact that the FXDS (dyna glide convertible) has a steeper head angle 28 vs 32 of the low rider. Any ideas? I was thinking about raked bearing cups? I read that just going with raked triple trees shorten the trail and will be it even more unstable. Or slap a dampener on it.
Old Jun 17, 2014 | 09:04 AM
falconbrother's Avatar
falconbrother
A buddy of mine lower and raked out a Yamaha Roadstar. It developed what he described as some pretty unsafe handling characteristics. He was told to lose the stock front wheel and install a 21 inch front wheel. He says that the handling issues cleared up. Not saying that will fix yours but, it's food for thought. My wife's sporty trike has a dampener on it and it helps a lot with wobbles and such.
Old Jun 17, 2014 | 09:23 AM
bluharley's Avatar
bluharley
The only thing that can pull you out of a speed wobble is more power and speed! My dad told me that long ago. Didn't help in my Pinto, had no more power!!
Old Jun 17, 2014 | 09:24 AM
tmanbuckhunter's Avatar
tmanbuckhunter
Until you have to come back through the head shake.
Old Jun 17, 2014 | 09:28 AM
zimm's Avatar
zimm
Well right now it's just a wobble that gets induced with a big bump. It settles out if I relax and put even pressure on both grips. But if I'm on the highway and just bump on the bars, it'll wag a few times, then steady out. I'm too scared to try and get it to really wobble. That's why I think it has to do with the 28 degree rake.
Beemervet's Avatar
Beemervet
What did you do to the suspension?
Old Jun 17, 2014 | 09:30 AM
zimm's Avatar
zimm
JRI 13" rear shocks. Front has racetech 1.0 straight rate springs and gold valves. So the forks ride a lot higher than then did, but also the rear is jacked up. I think that contributes to the steering. On sport bikes, raising the rear or lowering the forks just 10mm makes the steering sharpen up considerably.
Old Jun 17, 2014 | 10:37 AM
Throttle_Jockey's Avatar
Throttle_Jockey
Wasn't there a difference in the fxd models that had a +2" fork tube?
If your not already there maybe the front can be raised 2" to compensate for the raised rear. That way you don't loose the ground clearence/cornering you were looking for with the 13" shocks.
Old Jun 17, 2014 | 02:49 PM
Dr.Hess's Avatar
Dr.Hess
Try your original shocks and see if it's better.
There's a fine line between "more responsive" and "twitchy." Maybe you crossed it.
Old Jun 17, 2014 | 03:34 PM
Spanners39's Avatar
Spanners39
Experiment with your tyre pressures and make sure your neck bearings are adjusted correctly and check your tyres are compatible with each other.
streetboy80
May 5, 2020 08:22 AM
GoOrdnance
Jan 19, 2018 06:39 AM
GoOrdnance
Wheels/Tires
Jan 14, 2018 09:56 AM
DonN
Dec 21, 2017 09:50 AM
skidonkey
Oct 4, 2011 07:44 PM
