1981 Wide Glide
Old Jun 20, 2014 | 09:27 PM
acpartsman's Avatar
acpartsman
4th Gear
Default 1981 Wide Glide
Bought an 81 wide glide that's sat since 07. Did a search on net on how to change oil on a Shovel Head and the only thing I could find was to drain tank and add 4 qts. I drained the tank cleaned it and added 3 qts ran it and it's way over full on the dipstick. Did I missed a plug or receive bad information?
All responses will be appreciated.
Old Jun 20, 2014 | 09:30 PM
Uncle Larry's Avatar
Uncle Larry
You probably didn't run it before you changed the oil. They have a tendency to bleed oil out of the tank and into the crankcase. If you run it for a bit before you change the oil it will scavenge the oil from the crankcase back into the oil tank. After draining put three qts in fire it up and check it.
Old Jun 20, 2014 | 09:54 PM
acpartsman's Avatar
acpartsman
4th Gear
Default non vented Gas Tank
The bike I bought has an non vented gas tank with 2 21/4 flush mount caps they're not screw in so I can't find replacements for lack of better description they look like similar to a clover leaf that drops into a bung.
Can a person drill a small hole under the flip up latches to vent the tank halves?
Old Jun 20, 2014 | 09:59 PM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
Welcome to the Forum, acpartsman, that's a cool old ride you've got. Nothing beats the sound of a shovel. One caveat, this is the Evo forum, your welcome here as far as we're concerned, pull up a chair, kick back and open a beer! The guys here are some of the very best in the Forum, always willing to help!
But the moderators may have a different idea. Don't be surprised if they move your shovel posts......
Old Jun 20, 2014 | 10:03 PM
acpartsman's Avatar
acpartsman
4th Gear
Thanks. New at this I like this forum I'll stick to the beer drinking in the EVO site
Old Jun 21, 2014 | 08:12 AM
Dr.Hess's Avatar
Dr.Hess
Well, the '81 was better than the '79 (worst of the worst.) 79 FLH was 4 quarts with the filter cartridge in the tank. What is "way over full on the dipstick?" That would be about out the top of the tank, if I recall. Oil also goes through the primary, but I doubt a quart is hiding in there. If that's a factory gas tank, I wouldn't be drilling holes in the cap. I'd leave it as the MoCo put it there. What problems are you having with the gas tank?
Old Jun 21, 2014 | 10:19 PM
acpartsman's Avatar
acpartsman
4th Gear
just bought the bike I haven't had even had it out so no problems yet. The guy I bought it from said sometimes gas came out the carb.
Old Jun 21, 2014 | 10:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Did he say what part of the carb it was coming out?
Kees's Avatar
Kees
LOve the old shovels...I had a 1984 FXSB last of them, belt primary and final......but....
Old Jun 21, 2014 | 10:45 PM
acpartsman's Avatar
acpartsman
4th Gear
No he didn't say
