blinker problem
Old Jun 22, 2014 | 08:02 AM
SquirtGun's Avatar
SquirtGun
Originally Posted by Tailbreaker
I knew that was coming
Originally Posted by junglejoe
I didn't put the LED"S on until after I fixed the wires. I'm going to unplug it all today and put the stock stuff back and see what happens.. As far as the rear blinkers, I has flip one of the switches and turn the rear blikers OFF as running lights,if that what you mean mtlver..?
ALSO, THE BLINKER FLUID APPEARS TO BE JUST A LITTLE LOW!!
Nice pic....Great sense of humor....life is not life without it...
Old Jun 22, 2014 | 08:24 AM
Uncle Larry's Avatar
Uncle Larry
Good advice here from Ranger 73 ... and just in case ...
Old Jun 22, 2014 | 10:31 AM
Rabbito's Avatar
Rabbito
Uncle larry you know if you don't use synthetic you'll burn it out quicker. And jungle check your grounds that might be it or there's still fu('ed up wires somewhere
Old Jun 22, 2014 | 10:44 AM
br549A1's Avatar
br549A1
Joe, couple things. When I switched my signals to aftermarket, with one plugged in and one not they would not blink they would do what your describing so I know you're looking at the rear but make sure your fronts are kicking on too. If I disconnect or if my front bulb goes out I lose rear blinking. Two, some of these aftermarket a can be wired for running or blinking or both. Mine do this but my harness in the rear is set for only blinking. Front does both. If I miswire one of the back it will also do what your saying meaning if one rear wire was crossed it will do this. And lastly they sometimes use the stalk as a ground make sure your ground is contacting good. I had the same issue and thought I received faulty signals, just had to finish wiring everything up right for it to work.
Old Jun 28, 2014 | 06:59 AM
junglejoe's Avatar
junglejoe
UPDATE::: Well, seems that when I installed the LED kit, I couldn't understand, which way they were saying to plug in the resistor box first, either from the fender side or the main harness side...So after tearing everything back apart, rear tire off, all that mess looking at the wires..I simple had the resistor and the other control box "plugged" in backwards. Sometimes, you can be to smart for your own good!
Old Jun 28, 2014 | 07:38 AM
Uncle Larry
Hey sOmE tImEs OuR bRaIn SeEs ThInGs In dIFfErEnT WaYs ... Glad you got it figured out.
Seal
Jul 19, 2016 07:01 PM
LowRyd3r
Apr 22, 2016 07:35 AM
LowRyd3r
May 25, 2015 10:18 PM
nkauf21
May 2, 2010 05:40 PM
KENNYPOCONOS
Nov 12, 2008 11:31 AM
