1990 evo carb blows off intake
Old Jun 26, 2014 | 06:49 PM
johnm821's Avatar
johnm821
Stage II
Default 1990 evo carb blows off intake
My bike starts and runs fine until I turn it off. If it doesn't sit at least 5-10 minytes before I start it again it will backfire and blow the carb off. Once I put the carb back on it runs fine again.
Old Jun 26, 2014 | 06:59 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Wow!!!!!!!!!!!!!!!!
I wish I could help!!!
Old Jun 26, 2014 | 07:09 PM
apples402's Avatar
apples402
what kind of breather do you have? or are your brackets broken that old the backplate on? either way the backplate should be bolted to the motor which will in turn hold your carburetor in place.
Old Jun 26, 2014 | 07:18 PM
D_gyver's Avatar
D_gyver
what apple said broke bracket or lost bolts
Old Jun 26, 2014 | 07:23 PM
bluharley's Avatar
bluharley
I've had my carb blow out even with a good backplate and bolts. Not often, maybe 3 times in 8 years and then the one a couple months ago and the plastic around one of the backplate bolts broke and it fell out. Every time it backfires would point there.
oldwarrior's Avatar
oldwarrior
I had that problem once on my dresser, I replaced the intake manifold seals part # 26995-86A, something else is going on also, I would check the timing.
Old Jun 26, 2014 | 07:43 PM
oppirs's Avatar
oppirs
Red face
As a newbie. You blew it. So all is fine?
Keep here. A glitch to an EVO owner?
Many have done it.....not alone. Welcome to EVO
Old Jun 26, 2014 | 09:42 PM
cowboy 51's Avatar
cowboy 51
sounds like a bit to much fuel & timing off just a hair , along with bad backing plate
Old Jun 27, 2014 | 05:25 AM
Yankee Dog's Avatar
Yankee Dog
Yes, one would think that if the backing plate is properly secured, the carb will not blow off, so need to check that.
Then next issue, why is it backfiring? Like mentioned, timing, jetting, leaky intake seals at the head...Good luck YD
Old Jun 27, 2014 | 07:33 AM
Owtlaw's Avatar
Owtlaw
If the backing plate is messed up enough to allow the carb to blow off, the seal between the carb and the intake can't be very good. Could be the backfire problem right there. I'd secure the carb first.
