Speedo/Dash removal
Old Jul 4, 2014 | 06:46 AM
das56170's Avatar
das56170
Default Speedo/Dash removal
Probably a dumb question.
I'm trying to remove my dash and speedometer on my 94 fxstc. The manual says to remove the acorn nut just below the speedo and the "odometer **** screw" on the side of the dash. The pic in the factory manual is black and white and difficult to make out, but it looks like it's pointing to a nut on the side of the dash next to the trip-reset ****. My dash doesn't have any nuts, bolts, or screws on the side of the dash. So I took off the acorn nut below the speedo. The dash is loosened, but won't come off due to the speedo still being attached. Do I need to remove the trip-reset **** somehow. If so, how does that come off? I can usually figure simple stuff like this out, but I don't want to break anything. Thanks.
Old Jul 4, 2014 | 09:33 AM
Uncle G.'s Avatar
Uncle G.
The trip reset **** has to be removed to remove the dash cover. The reset **** is held on by a TINY Phillips head screw in the center hole of the ****. Use a miniature Phillips head screwdriver to remove it, then slide the reset **** off.
Old Jul 5, 2014 | 07:14 AM
das56170's Avatar
das56170
Thanks. That worked.
Old Jul 5, 2014 | 11:43 AM
Beemervet's Avatar
Beemervet
Those ***** are notorious for falling off. Use a tiny dot of loc-tight when you reassemble.
Old Jul 5, 2014 | 05:23 PM
das56170's Avatar
das56170
Will do. Thanks for the advice.
Old Jul 5, 2014 | 06:57 PM
Uncle G.'s Avatar
Uncle G.
Don't use too much, or you will strip the screw head next time you have to remove it.
Personally, I've never used Loctite on anything on the outside of my bike and never had anything fall off either, but then.....
Old Jul 6, 2014 | 04:48 AM
grbrown's Avatar
grbrown
That screw is the smallest part on a Harley I have come across that most of us are likely to bump into. I have a suitable screw-driver dedicated to that and that alone!
PurpleHazeDeuce
May 10, 2019 09:07 PM
PurpleHazeDeuce
Electrical/Lighting/Alarm
May 6, 2019 04:56 PM
zukeeper
Nov 27, 2010 04:51 AM
twoton
General Topics/Tech Tips
Jul 25, 2010 02:00 AM
07deluxe
Apr 21, 2007 12:47 AM
