Caliper update question
Old Jul 8, 2014 | 07:39 AM
johnod's Avatar
johnod
Originally Posted by grbrown
John, the 'diameter' of the axle is dictated by the bearing size. So your bike with 3/4" ID tapered roller wheel bearings uses an axle of that OD size, however that is only the diameter where it passes through the wheel. One end is larger than that, the other is smaller.
Later bikes have either 1" bearings or 25mm ones, but the two axles of those sizes will both fit the later sliders, because the 'big' and 'small' ends of those axles are the same sizes. I suspect the 'small' end is the same for your earlier bike as well. What we need is someone to tell us if the 'big' end is the same size as later axles.
In any event either a 1" or 25mm axle will have enough meet on it for you to make any alterations to it, so it fits your 3/4" wheel.
Thanks that helps.
Old Jul 8, 2014 | 07:43 AM
grbrown's Avatar
grbrown
Red face
Originally Posted by johnod
Thanks that helps.
I should have said 'meat', not 'meet'! I'll change it.
Old Jul 8, 2014 | 08:40 AM
rivercityslim's Avatar
rivercityslim
OK, this may seem to be a stupid question, but I'm going to ask anyway. All this talk of going to the newer brake setup requires a lot of new parts, from the new lowers to the new calipers, rotors, axle and possibly the wheel itself.
Is there another way to increase the front stopping power on an older Evo (an '89 FLHTCU in my case) using the existing fork and wheel setup? Does someone make calipers/rotors that fit the old forks that will provide significantly improved braking?
Old Jul 8, 2014 | 08:50 AM
Beemervet's Avatar
Beemervet
'00 and up calipers with adapters can be done for not much more than $100.
Old Jul 8, 2014 | 10:12 AM
grbrown's Avatar
grbrown
Wink
Then add braided lines and perhaps Lyndall pads, for that little extra!
Yes there are bolt-on alternatives, such as PM calipers and even larger diameter rotors, but most of that stuff is only available new, hence expensive.
Old Jul 8, 2014 | 02:16 PM
HGM's Avatar
HGM
The big end of the 1" axle is 1.120", no step down.. The left side was still 3/4", the right side was the main difference, plus the caliper mounts of course.. So, if you're going with '00-up lowers, the 1" and 25mm axles will be the same except for the section between the legs.. With the lowers, you could go with either the '00-07 calipers and factory rotor for '86??-'07 or Brembo's with '08-up rotors.. Hope that helps.. As for the line, I cheaped out and used a new take off that came with the calipers, more nylon than rubber, great feel to them..
On a side note.. My Dyna has the '00 lowers and caliper, stock rotor and caliper ('96) and stops MUCH better than factory.. Dressers changed the axle earlier than the other bikes, I think the Dyna changed in '04, but dont quote me on that..
Old Jul 18, 2014 | 09:49 PM
johnod's Avatar
johnod
Well I got a set of lowers and a front caliper/master/lines etc from an 06, and axle is on the way.
Anyone know if the master will fit the 97 bars/switches?
I hope.
Old Jul 18, 2014 | 11:10 PM
Wanna Ride's Avatar
Wanna Ride
I hope.
What model bike was the '06? The touring bikes didn't get Brembos until '08.
Old Jul 19, 2014 | 12:05 AM
johnod's Avatar
johnod
They're not brembos.
jman1115
Feb 13, 2017 06:31 PM
glcash
Nov 25, 2012 11:05 PM
Corvarepairables
Feb 6, 2010 09:11 AM
Beemervet
Aug 15, 2008 12:16 PM
BuckeyeFanInFL
Dec 14, 2006 12:01 PM
