Caliper update question
Old Jul 4, 2014 | 11:32 PM
johnod's Avatar
johnod
Default Caliper update question
Thinking of doing a caliper update on my 97 FLH.
Thinking of using newer HD/Brembo units.
What year did HD go to the 4 piston caliper, and are there any specific years that are better or worse.
Thanks
Old Jul 5, 2014 | 12:29 AM
Spanners39's Avatar
Spanners39
Changed in 2000 and there are no bad or good years.
Old Jul 5, 2014 | 07:09 AM
HGM's Avatar
HGM
As Spanners said, '00.. You should also remember, they went Brembo in '09... doing the '00-'08 upgrade will only require lowers. Brembo's will require new rotors too..
Old Jul 5, 2014 | 10:00 AM
johnod's Avatar
johnod
Thanks, that info helps a lot.
Old Jul 5, 2014 | 11:46 AM
Beemervet's Avatar
Beemervet
No lowers required with adapters.
Old Jul 5, 2014 | 01:08 PM
HGM's Avatar
HGM
If you like the looks of the adapters..
Old Jul 5, 2014 | 01:12 PM
grbrown's Avatar
grbrown
I've been browsing around this subject and the '09s and later have -00 sliders, so Brembos should fit all '00-on sliders, as long as the larger 300mm rotors are used. So adapters do indeed allow our ole ladies to use Brembos!
Old Jul 5, 2014 | 01:16 PM
HGM's Avatar
HGM
Originally Posted by grbrown
I've been browsing around this subject and the '09s and later have -00 sliders, so Brembos should fit all '00-on sliders, as long as the larger 300mm rotors are used. So adapters do indeed allow our ole ladies will use Brembos!
That is a fact, and certainly a cheaper option.. Depends on what your after I guess.. I like the factory look, myself.. With your plans, the bracket may very well be your best option Graham..
Old Jul 5, 2014 | 01:24 PM
Wanna Ride's Avatar
Wanna Ride
Brembos were added to the touring line before '09, they were added in '08. Brembos use a slightly larger rotor, up from the previous 11.5" to the 11.8".
This is a great upgrade from the older braking systems. Be sure to include the Brembo master cylinder for maximum performance.
Old Jul 5, 2014 | 02:22 PM
Tee&Vee's Avatar
Tee&Vee
I believe the 2006 vrod came with the current generation brakes. Been wrong before.
