Wheel Spacer Question
Old Jul 13, 2014 | 10:05 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Kabear
The method described me is in my 1985 HD manual.
So I would ***-u-me that the procedure was around in 1985!
I was never doubting that it is in the earlier manuals.
As I said it is a different procedure in my '95 HD manual.
You can accomplish the same thing with a screwdriver as you can with a drill bit and a screw driver has no sharp edges.
I just checked a '91 manual and it doesn't have the drill bit either.
So that means they changed sometime between '85 and '91.
I am still curious as to when they changed the procedure in the manuals.
Old Jul 13, 2014 | 10:44 PM
cowboy 51's Avatar
cowboy 51
I don't think I would grab a drill bit either ,I've always used a screw driver , don't care what any book says
Old Jul 14, 2014 | 07:25 AM
Uncle G.'s Avatar
Uncle G.
Mine looks just like that, and always has, no matter how many times I've had the wheel on and off (dozens of times now).
The right hand end of the axle is larger in diameter than the part that passes thru the spacer and the wheel.
Old Jul 14, 2014 | 08:15 AM
larsfum's Avatar
larsfum
Thanks again for the input. I did tighten the axle to 55 ft-lbs while holding the other end with a screwdriver (That is what my SM says to use). Then I tightened the pinch bolts. It seems to be OK. Rode out to the beach yesterday, and she tracked well.
Old Jul 19, 2014 | 06:26 PM
0734's Avatar
0734
Screwdriver, big nail, bolt or maybe even a sharp stick will work. If you have Godzilla hands, that will also work. MOCO must have got a good deal on (or ordered in error) thousands of drill bits and wanted to sell them as "special tools". It's a wonder they did not find a way to incorporate the bits inside the engine under three covers that had to be removed (including the exhaust) as a part of some sort.
Old Jul 20, 2014 | 08:19 AM
junglejoe's Avatar
junglejoe
Went and looked at mine, it is NOTHING like that! The spacers are flat against the forks
Old Jul 20, 2014 | 08:45 AM
0734's Avatar
0734
Doesn't matter what you use or what it looks like....within reason. The right side should not be tightened (pinch-bolts) until the axle nut has been torqued. Assuming one has the spacers installed in the right place (spacer is also meant to be used in the same terms as the mechanical speedo sending unit on the left side if so equipped).....the right fork will "find itself" on the axle....then tighten the pinch bolts leaving an equal amount of space on either side of the cap. If one tightens the pinch-bolts on the right side first, then torques the axle nut, the forks can be warped inward.
As you stand in front of the scooter....do the right (nut side) first 50-55 pounds, then the cap-screws on the left side.
Old Jul 20, 2014 | 12:08 PM
texashillcountry
Dirt don't hurt
This is the reason my manual says loosen and re-tighten the cap nuts after tightening the axle nut.
If you do that the fork will shift back out and be fine.
But I'm with you. It is easier to stick a screw driver in the hole and only tighten the cap nuts once.
TonyRei
Mar 15, 2018 05:02 PM
booze hound
Jul 14, 2013 10:10 PM
HDCPL4PLAY
Feb 12, 2009 09:04 PM
tweeker
Feb 15, 2008 05:56 AM
03RKC
Apr 5, 2007 09:01 PM
