primo rivera starting issues help!!!!!!
Old Jul 14, 2014 | 06:00 PM
polish hammer's Avatar
polish hammer
Default primo rivera starting issues help!!!!!!
ok here's my settup
i have an s&s v111" super stock ignition
using the stock inner and outter harley primary (vented)
a primo rivera 1 3/4" brute 3 belt drive
a rev tech 6 speed tranny
a spyke 1.4 kw starter
and a drag specialties battery (gel)
my problem is every like 3rd or fourth start its grinding kinda like
when you restart your car??
when it was happening or i should say b4 it happens i'd leave it in first gear bump back on the starter then pull clutch and start it seemed to clear it up
i havta test that again though
ok other thought may be crazy i swapped out the old starter bolts for stainless steel versions of them now i'm thinking is it possible these bolts which stretch more than grade 8 bolts...are they loosening up under the pressure???
Old Jul 14, 2014 | 06:12 PM
junglejoe's Avatar
junglejoe
I have their 3 inch open belt , Sometimes mine will do that, I have checked everything.I believe mine is doing it right when the bike shuts off and lands on a compression stroke..
Old Jul 15, 2014 | 06:06 AM
polish hammer
Default how too fix it?
this is my bike
but how to stop that grind noise
Old Jul 17, 2014 | 06:39 AM
junglejoe's Avatar
junglejoe
You say 3rd or 4th try, maybe you're draining the battery down after trying to crank it. Whats the clearance on the starter shaft and the flywheel? Might need to shim it.
Nice ride by the way!
Old Jul 17, 2014 | 06:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Moving the bike back and forth won`t do anything, because the starter can only be rotated if the starter pinion gear is engaged. Unless you are doing this while the start button is pressed...
I think the starter clutch is your problem.
Old Jul 17, 2014 | 08:25 AM
traildog's Avatar
traildog
Or a combo of low battery AND clutch. Had that happen twice on my last bike (starter clutch).
Old Jul 17, 2014 | 10:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Old Jul 17, 2014 | 06:36 PM
polish hammer
well why i think it's happening or i should say why bouncing back on it is working is the pinion gear is getting caught....talking with the guys from spyke they sent me a simple relay settup to circumvent my thunder heart controller stating the thunder heart controller uses a micro 30a relay and when it get's hot is not enough to turn the starter and return the pinion gear
polish hammer
ps how do you shim the pinion gear?
Old Jul 17, 2014 | 07:14 PM
junglejoe's Avatar
junglejoe
You shim the jackshaft with the right thinkness spacer(washer) You should check and see what your clearances is before ordering the shim kit
portaman03
Shovelhead
Aug 16, 2013 10:36 PM
Nazarah
Mar 26, 2011 07:04 PM
pedulla242
Mar 5, 2011 05:56 PM
Spades
Shovelhead
May 10, 2010 10:26 AM
TIPN8R
Oct 12, 2008 04:25 PM
