Starter problems...
Old Jul 15, 2014 | 03:30 PM
splittie65's Avatar
splittie65
Thanks all for your comments so far.
Originally Posted by texashillcountry
Be aware that while the fused wire will solve the dreaded click 95% of the time it won't always fix it.
On rare occasions there is something else going on.
This is the reason for my question......is it likely to be the solenoid itself?
Is there a way to check it before cutting into my wiring loom?
Old Jul 15, 2014 | 03:36 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
There is no need to cut into your wiring at all.
Simply remove stock female spade connector from connector block and replace with a regular one.
You will need a very small screw driver to press down the tab to get out the oem connector and maybe a pair of small needle nose pliers to insert new connector through the block (this is what I did but it has been a while).
Don't forget to wrap up oem connector with electrical tape!!!!!!
Old Jul 15, 2014 | 04:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You can also remove the cover from the end of the solenoid and take a look at the contacts.
If they are looking tired, you can get all the parts at a starter repair shop.
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted double post...
Old Jul 16, 2014 | 06:19 PM
machinehed's Avatar
machinehed
All good advise . Check all connector blocks and wire connectors etc.
A wet paste of arm and hammer and water will remove the elec. corrosion .
Flush off the paste and add a bit of white grease to the connectors to prevent future corrosion., this is standard operating procedure with old wiring / connectors.
I suspect your problem is a dirty start switch , disconnect battery , use WD40 or your choice of cleaner and with the nozzel provided , shoot a spray directly into all switches while activating the switches . When what drains out is clear , that switch is clean. Do all.
If you have access to comp. air blow out the switches , if no access to comp. air let bike sit for a night or blow out the switches with a straw and lung power.
You will be surprised how much crap is flushed out of 20 year old bar switches.
Summers420us
EVO
30
Feb 22, 2023 03:10 PM
marktruckee
EVO
Feb 24, 2016 07:20 AM
Donn 86 flhtc
Mar 4, 2015 07:42 PM
NB Biker
Aug 23, 2014 06:54 AM
NickSchoff
EVO
Apr 5, 2013 08:26 AM
