Strange Speed wiggle
Old Aug 9, 2014 | 07:01 PM
boygenius's Avatar
boygenius
So I tightened up the front end and it helped slightly but the wiggle is pretty bad still I can't really ride over 60 , I made a an real effort to watch what happens and the bars don't seem to be moving , ill be riding at 70 on glassy smooth pavement and its like the tires are wobbling even tho they aren't it's just the best way I can explain it. I its pretty severe wiggle like cars behind me have tried to get next to me to motion something is wrong as if I didn't know
boygenius's Avatar
boygenius
Also the only way to stop it is to slow to 60 or lower
Old Aug 9, 2014 | 08:40 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I had a friend of mine who told me he knew how to set my fall away.
Like a dumbass I let him.
Basically what he did was loosen my neck bearings to where he thought they should be.
After he did it I had the same problem you have except I could get to 80 before it happened.
I tightened them back up and it is fine now.
If you can't tighten yours enough I would look at replacing the neck bearings.
Old Aug 9, 2014 | 09:20 PM
Beemervet's Avatar
Beemervet
Do you have the factory manual so you could do the tightening procedure correctly? When you had the front wheel off of the ground did you check for slop by pulling and pushing the front wheel front to back? Did you slowly rotate the bearings to feel if the races are notched at center? The fall-away test is almost subjective, and can't be relied on to diagnose the above issues.
BTW, just because the front end isn't wobbling doesn't mean anything. Ever hear of the tail wagging the dog?
Old Aug 9, 2014 | 11:22 PM
boygenius's Avatar
boygenius
I'm pretty sure the neck bearing is plenty tight enough , I just had new bearings put in front and rear thinking that was issue. There is no play in wheel when its off ground whatsoever front or rear
Old Aug 9, 2014 | 11:30 PM
boygenius's Avatar
boygenius
Whats the best way to turn the star adjuster for steering stem its a real ..... To get to
Old Aug 9, 2014 | 11:35 PM
tmanbuckhunter's Avatar
tmanbuckhunter
My dyna will wobble at times but it's not up front, it's in the rear. The whole rubber mounted death wobble thing... all it tells me is MORE THROTTLE.
Old Aug 10, 2014 | 06:27 AM
bagga's Avatar
bagga
if you have spokes check them for tightness. start with the rear wheel. if the rear spokes are loose the front end will shake.
Old Aug 10, 2014 | 08:47 AM
boygenius's Avatar
boygenius
Rhettm
2014-2024 Touring Models
24
Jul 31, 2021 07:03 AM
irtmks
Jan 11, 2019 04:19 AM
TnFatboy
Dec 5, 2018 05:49 PM
TAWoody
Jul 21, 2010 08:47 PM
phatsanders
Sep 3, 2009 09:28 AM
