Manifold gaskets.....Please explain
Old Aug 13, 2014 | 06:32 PM
traildog's Avatar
traildog
Default Manifold gaskets.....Please explain
How can a smaller, thinner gasket seal better than a larger thicker one?
I received the S&S gaskets from THC (thanks man) and whipped out the dial calipers.....
The stock HD gasket is .294 tall and .127 thick
The S&S gasket is .240 tall and .113 thick
What the?!?!?!?!?!?!?!?
Old Aug 13, 2014 | 07:12 PM
FlamedFXR's Avatar
FlamedFXR
Do you have an S & S manifold? I have an S & S and I prefer Harley seals for a better fit.
Old Aug 13, 2014 | 07:22 PM
traildog's Avatar
traildog
That's just it, I have the S&S manifold and HD seals installed, but, the S&S guy says their seals are the ones to use............
Old Aug 13, 2014 | 07:33 PM
WP50's Avatar
WP50
Is there a difference in diameter? Depth of recess in Manifold? TD
Remember someone mentioning a difference in an older S&S and a newer one.
Old Aug 13, 2014 | 07:41 PM
traildog's Avatar
traildog
Yea, the newer manifolds are a larger diameter......
Old Aug 13, 2014 | 08:09 PM
WP50's Avatar
WP50
Any chance S&S set ya the wrong o rings
That sure looks to be alot difference. If you were having trouble getting the manifold installed right with the HD rings, thinner S&S rings would make sense.Umm Dang things that make go Ummm.
A couple years ago I was thinking well. This bike is giving me more trouble than my wife. I looked into trading it. Them I remembered times when the wife was more trouble than the bike. I just kept them both
Hope ya get figured out WP
Old Aug 13, 2014 | 08:25 PM
traildog's Avatar
traildog
Actually, THC sent me the smaller S&S seals....I bought 2 sets of the HD seals. One set is installed.
Yea, I'm keeping both also..........for now.............
Old Aug 13, 2014 | 08:50 PM
Throttle_Jockey's Avatar
Throttle_Jockey
Unless something has changed a Super E uses stock size Harley O-Rings. Super G uses the thinner O-Ring due to the difference in manifold sizes.
Old Aug 13, 2014 | 09:10 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Something did change.
Back in 04 S&S made their intake manifolds bigger.
Old Aug 13, 2014 | 09:13 PM
traildog's Avatar
traildog
I'm calling s&s tomorrow to figure out if I have a pre or post 2004 manifold.
Do you know the OD's?
