Default 1993 FLHTCU Low Accessory Voltage
Old Aug 17, 2014 | 02:06 PM
drm1978's Avatar
drm1978
Hello all! My wife's brother passed away two years ago, and she wanted me to restore his 1993 Harley Electra Glide Ultra Classic. It has been in storage...unused...for nearly ten years.
Over about a 2 year period I cleaned it up a bit, gave it new tires, new brake pads front and rear, flushed the fluid, replaced the main drive belt and changed the oil. I also rebuilt the carb and gave it new plugs. It runs pretty well except that the idle is a bit high after warming up (~1200 rpm), but that'll be easy to fix. My bigger issue is that I failed my Maryland State inspection because of all things, my horn didn't work. Well, it turns out that although my battery is being charged and stays up around 12.5V, the auxiliary circuit (the orange wires) hovers around 10.5V although it'll sometimes jump up to over 12V. I can't quite figure out the pattern. So, if the voltage is low, the horn doesn't work.
So what can it be? The charging system appears to be working. I'm guessing there's a voltage drop across one of the circuit breakers behind the main fairing or across the ignition switch itself.
Can anyone offer an suggestions?
Thanks!
Old Aug 17, 2014 | 03:14 PM
M1dniterider's Avatar
M1dniterider
Could be a bad ground.
Old Aug 17, 2014 | 04:25 PM
Owtlaw's Avatar
Owtlaw
There's a bad connection somewhere for sure, and it sounds like your'e on the right track. Meanwhile, you could wire the horn with a relay and get it to work to pass the test.
Old Aug 17, 2014 | 06:23 PM
bagga's Avatar
bagga
the 15 amp accessory breaker might be going south. you can get them at any auto parts store. i had to order them because they didn't have them in stock.
drm1978
Shovelhead
Aug 17, 2014 10:46 PM
Red 62
Electrical/Lighting/Alarm
Aug 7, 2014 07:56 PM
mannyb
May 30, 2011 01:46 PM
bmorebhoy
Jan 22, 2009 11:45 PM
problem solver
Aug 4, 2008 06:38 PM
