Outer Primary Fitment?
Old Sep 8, 2014 | 07:12 AM
0734's Avatar
0734
Default Outer Primary Fitment?
Need a replacement outer primary cover for a 98 RK Anniversary. The parts list I can find specify 60665-94 or 60664-94A. I have found a good 60685-94A that was removed from a 98 RK. It all looks the same. I want to send one out for sand-blasting and powder-coating and if the 60685 will fit, I won't have to remove the one on the bike now...I can just have the 60685 refinished and make the change in one remove/install.
Do any of you parts guru's have any reason to believe the 60685 won't work? I believe that PN was specified in the 96 touring family. My 98 RK is EFI, but I see no reason why that would have any effect on the OP fitment.
I don't want to have the 60685-94A refinished only to discover it won't fit.
Reason....I have some "cancer" under the chrome on a few parts and am having these parts refinished and color-keyed to the bike.
Old Sep 8, 2014 | 12:27 PM
MIKE93SVT's Avatar
MIKE93SVT
ronnie's parts finder cache (google it). good online source for part numbers and exploded view. similar to parts manual.... says this:
mike
60665-94 COVER ASSEMBLY, PRIMARY (CHROME)
Old Sep 8, 2014 | 12:33 PM
MIKE93SVT's Avatar
MIKE93SVT
the other part number shows similar models. so it "should" fit. if it's cheap, buy it and sell if it doesn't bolt up properly
http://www.ebay.com/itm/1998-Harley-...5ae064&vxp=mtr
Old Sep 9, 2014 | 02:39 PM
0734's Avatar
0734
Thanks....I don't have any reason to believe that it won't. It looks like a duck, walks like a duck and quacks like a duck...maybe it's a duck? The 85 was "cheap" so I bought it after making sure the drain screw threads were in good shape. It had some scratches and dings, but that (at this point) doesn't matter. I was going to have one sandblasted and painted anyway. My reasoning was that if I could find a solid used one, I did not have to take the time to remove the one on the bike and send it out....being without a ride for the turn-around.
Looking at the RK Anniversary clutch parts, they appear to have advanced the 98 model year to the 99 and newer diaphragm spring configuration (6-screws hold it in place...no internal snap ring). It does have a thicker derby cover and that may make it all work if the clutch is a problem. The covers are both three-hole and are identical in appearance and mounting. This 85 came off a 98 RK, or so I was told and it had the regular sized (dome) derby cover on it.
Old Sep 9, 2014 | 08:33 PM
Jasper86's Avatar
Jasper86
if ya wanna mess with people, a twincam OP cover will fit too (up to 05 or 06...I know because i mocked one up on my 98 RKC...wasnt gonna help me though...was testing for clearance with the bandit clutch)
Old Sep 9, 2014 | 09:01 PM
WP50's Avatar
WP50
I have one of a 97 FLHT Standard. Your welcome to it for shipping if ya can use it. The drain plug was setting a bit deep but did ok. I changed it out for a chrome one.
WP
Old Sep 10, 2014 | 03:46 AM
0734's Avatar
0734
WP.....PM sent. Thanks for the offer.
Old Sep 12, 2014 | 01:46 PM
WP50's Avatar
WP50
Sent ya PM about shipping
WP
Old Sep 20, 2014 | 06:20 AM
0734's Avatar
0734
THANKS WP!
We all know that when you get a little cancer under chromed aluminum....it becomes a worm under there that simply doesn't stop. Any bike that lives in a coastal environment can be more problematic. Once you get a scratch through the chrome, that's all it takes to ruin a chrome plated finish.
This one you made me a terrific deal on is polished aluminum and I've been seeking/changing all the chromed parts out to polished aluminum anyway. You made me a deal I could not refuse and I have a friend that's a welder. I'll just weld that oil-drain hole up and re-tap it.....can't do that to a chrome part and simply polish it out.
Thanks again!
Old Sep 20, 2014 | 07:25 AM
WP50's Avatar
WP50
LOL Just sent a Pm and flipped back here and saw this.
Your more than welcome.
Have a good 1
WP
Mike Lawless
31
May 1, 2018 10:27 AM
MachU
Nov 10, 2015 07:22 AM
soft 02
Apr 12, 2010 08:12 AM
malo
Good Or Bad Shopping Experiences At HDF
Aug 14, 2008 01:49 PM
homefront
May 21, 2008 04:15 AM
