Replace 1997 Front End with 2013 Parts?
Old Sep 13, 2014 | 06:18 PM
BadHabit's Avatar
BadHabit
Default Replace 1997 Front End with 2013 Parts?
Looking for some help/info. I have a 97 Ultra with fork lowers that are the worse for wear and tear. Through a friend I have the opportunity to purchase off of a 2013 Street Glide the following...
Fork lowers along with 18” factory front and rear rims and tires. The front wheel comes with the Brembo calipers, rotors and lines for what I consider a fantastic price of $350. My questions are these..
Will these 2013 Fork LOWERS fit my 1997 Forks? A plus would be the ability to replace my current 16” rim and Two piston calipers with the 2013 18” rim and 4 piston Brembo calipers and rotors. So whats the verdict? Is it a bolt up or am I looking at modifications and if so what are they? Thanks folks for any help.
B.H.
Old Sep 13, 2014 | 06:25 PM
Tee&Vee's Avatar
Tee&Vee
No flipping way it's gonna fit. You better let me have his phone and address so I can spare you the heartache.
Rear wheel ain't gonna work with you current swing arm.
Tom
Old Sep 13, 2014 | 06:39 PM
BadHabit's Avatar
BadHabit
Just the front Is what Im hoping will work...And what would you put it on? lol
Old Sep 13, 2014 | 08:32 PM
Tee&Vee's Avatar
Tee&Vee
If he's rolling 41 mm tubes then his lowers gonna swap right over. Other than the mismatch tires you're gonna run, which don't mean Jack, you'll have a mighty nice setup for $350 and four cervezas. Ain't gonna take you three hours to swap front ends and do Spanner's ground up bleeding.
Go for it!
Tom
Old Sep 13, 2014 | 08:34 PM
Tee&Vee's Avatar
Tee&Vee
Wink
Originally Posted by badhabit
just the front is what im hoping will work...and what would you put it on? Lol
1998 fltr
Old Sep 13, 2014 | 09:42 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
According to this website I think the '13's are still 41 mm witch means it will switch just fine.
http://www.motorcyclemetal.com/gpage25.html
If I'm reading it right FLT models didn't go to 49mm 'till '14.
Hope this helps
Old Sep 14, 2014 | 07:51 AM
BadHabit's Avatar
BadHabit
Thumbs up
Hope this helps
Great info thanks
Old Sep 14, 2014 | 08:26 AM
texashillcountry
Dirt don't hurt
Originally Posted by BadHabit
Great info thanks
If I were you I would call the local dealership and double check just to make sure.
Old Sep 14, 2014 | 11:30 AM
grbrown's Avatar
grbrown
Thumbs up
It can be done, there is some useful info here.
Old Sep 14, 2014 | 09:27 PM
kona74's Avatar
kona74
For $350, you can sell it without any loss if you change your mind.
Radicult
Jan 21, 2018 12:16 PM
Jagg11
16
Aug 2, 2017 05:04 PM
BadHabit
Sep 14, 2014 06:56 PM
RE AND CHERYL
Jun 14, 2009 04:11 PM
OldIronFLT
Nov 3, 2006 07:00 PM
