CAM UPGRADE READING?
07 fxstb
hypercharger w/ K&N
V&H stepped drags
PC111
Here are my thoughts, after all the talk on the thread about CR and the effects of milling heads and top of jugs, this is the scenario of what I'm gonna do.
First
Screamin Eagle Pro Big Bore Stage II Kit - 1690cc (Black)
Your Price: $899.95 Item Number29893-07 Stock Status
please read not in stock Model FamilyN/A Weight31lbs.
Includes Stage II (SE-255) cams, Big Bore cylinders, Big Bore flat top pistons, clips, and a Stage I Air Cleaner Kit with one piece backplate, integral breathers, all mounting hardware, and gaskets. also includes a high performance clutch spring. Cam Spacer Kit P/N 25938-00 is recommended. This kit contains an assortment of 5 different spacers to achieve proper sproket alignment. Individual spacers can be purchased seperately. Requires seperate purchase of primary cover gasket. Not all compononts shown. For race application only.
Fits '07 Twin Cam equipped models
SECOND replace pistons with these to get to 10.25 -1 CR
1550 High Compression Cast Piston Kits-Standard Bore. Big Bore
Your Price: $129.95 Item Number22661-99A Stock Status
please read
in stock Model FamilyDyna Touring Weight8lbs.
1550 High Compression Cast Piston Kits-Standard Bore. Big Bore [font="verdana,arial,helvetica"][size="2"]
(Pair) Screamin’ Eagle® Twin Cam 88® High Compression Cast Piston Kits. 10.25:1 cast pistons
should I go with the flat tops and mill the heads and jugs?
I know the pistons are cast not forge buttt....
Thoughts and opinions are readily welcome......anyone see any holes in my plan?
Cast is fine for anything near sane street use.
JB
