Engine not running properly
Old Apr 20, 2007 | 11:18 AM
vthunder's Avatar
vthunder
6th Gear
Default Engine not running properly
I just completed rebuliding the top end of my 2003 roadking . I installed 10.5/1 KB pistons, 95 inch screaming eagle heads, ported and polished HD heads with new valves,guides and new stock springs, and andrews 37b cams. The engine is not running right, the back cylinder sounds like it is running properly , but the front cylinder sounds like it is running real fast, and making a pecking sound from the exhaust.I did the work myself, I followed the procedures in the service manual .What is the most likely cause for this??? [sm=feedback.gif]
Old Apr 20, 2007 | 12:20 PM
04RoadKing's Avatar
04RoadKing
Default RE: Engine not running properly
You might try checking to see if you have a intake leak.
Old Apr 20, 2007 | 08:37 PM
Sleeps In Trees's Avatar
Sleeps In Trees
Cam timing? Have you done a compression test?
VicW.
Old Apr 22, 2007 | 07:55 AM
sgt joe's Avatar
sgt joe
is it idling right ? is it ROUGH when you advance throttle ? both cylinders same temp ?noises can be VERY deceiving......might be something as simple as an exaust leak......spray soapy water over exaust flange......if you get bubbles you gotta exaust leak.......always check the SIMPLE STUFF first......If no exaust leak, i certainly agree about a compression check etc being done....
Z
Engine Mechanical Topics
24
Jul 30, 2022 09:28 AM
ohioflhs
29
May 27, 2015 02:06 PM
HDF Tech
Oct 5, 2010 06:31 AM
vthunder
Apr 19, 2007 07:45 AM
bluezguy
Shovelhead
Jul 27, 2006 12:33 PM
