Check engine light on??
Old Apr 23, 2015 | 08:27 AM
NP9's Avatar
NP9
Stage II
Default Check engine light on??
Hey guys,
Pretty new to installing my own exhausts and air cleaner. I've done it successfully twice before....Now I have a Dyna FXDB and I installed the VH short shots and an Arlen Ness Big Sucker...after I got done, I went to turn her on and my check engine light will not go off. I checked my 02 sensors and those are nice and snug....any ideas??
Thanks!!
Old Apr 23, 2015 | 08:47 AM
touchdown's Avatar
touchdown
now you need a tuner and a dyno tune.
Old Apr 23, 2015 | 09:11 AM
NP9's Avatar
NP9
Stage II
But will that fix the check engine light? The other 2 installs I had, the check engine was not on...this was also before I got it tuned and dyno'd
Old Apr 23, 2015 | 09:28 AM
xzatx's Avatar
xzatx
run the diagnostic on your bike. how to run it should be in your manual, it will give you a code then you can search the code and see what it is about.
on sportster it used to be, you hold the button on the speedometer (in the back of it) and turn on the key to ACC keep holding then OBD comes up and it will show up any codes you may have.
Old Apr 23, 2015 | 09:29 AM
xzatx's Avatar
xzatx
here is how
https://www.hdforums.com/forum/dyna-...lear-them.html
Old Apr 24, 2015 | 09:49 AM
enodrano's Avatar
enodrano
First check your error code:
It is most likely a o2 sensor error. When you increase the airflow by upgrading to a high flow air cleaner and a less restrictive exhaust the stock ECM map will cause the engine to run way too lean.
You can also clear the code and see if it comes back.
BigTasty
Dec 18, 2011 02:51 PM
mazurusmc
Sep 5, 2010 06:45 AM
phreak
Jul 21, 2007 09:17 AM
Sleeps In Trees
Dec 1, 2006 03:11 PM
20NightTrain03
Jul 6, 2006 12:00 AM
