Push rod adj help
Old May 6, 2007 | 01:31 AM
AMRAAM's Avatar
AMRAAM
Default Push rod adj help
I have just completed putting in a set of HeadQuaters cams to my 05 FLSTFI.
I purchased a set of SmithBros. push rods, adjustable type. have snuged these up between the lifters and rocker arm. Can twist slightly by hand but there is no end play.
How many turns do I want to put on to the rod, 1 or 3? have seen both numbers. Does the cylinder need to be @ TDC when this adjustment is being performed? Any help is apreciated Thanks
Old May 6, 2007 | 06:44 PM
mtnlvr's Avatar
mtnlvr
Default RE: Push rod adj help
I hope you've already found your answer. I searched their website (cuz my bike is out-of-commission for a while and have nothing better to do) and found nothing.
It varies between pushrod manufacturers depending on the adjuster thread pitch.
You'll have to refer to the documentation that came with the pushrods or give them a call.
Old May 6, 2007 | 07:11 PM
Hammer02's Avatar
Hammer02
How many threads per inch are your pushrods?
That will determine how many revolutions to spin the pushrod.
Old May 6, 2007 | 08:42 PM
Bryan1724's Avatar
Bryan1724
Reference for adjusting Pushrods
Stock HD and most aftermarket hydraulic lifters (except the "hydro-solids" type) require a preload of .100 +/- .010.
Here are the most common pushrods and their thread pitch
Brand TPI
Jim’s Pro-Lite 24
Slim Jim’s 32
Andrews 28 or 32
Crane Timesavers (new type) 28
Crane Timesavers (old type) 24
Harley 32
S&S 32
Screaming Beagle 32
Rivera Taper-lite 40
Rev-Tech 36
If you want to depress the hydraulic unit .100 and the thread pitch (for example) is 40, that would need 4 full turns or 24 flats. Hex nuts have 6 flats per turn.
What’s all this mean?
For 24 TPI you would turn 15 flats to get a preload of .1042
For 28 TPI you would turn 17 flats to get a preload of .1011
For 32 TPI you would turn 18 flats to get a preload of .0937
For 36 TPI you would turn 21 flats to get a preload of .0965
For 40 TPI you would turn 24 flats to get a preload of .1000
Old May 7, 2007 | 12:50 AM
mtnlvr's Avatar
mtnlvr
Keep in mind that not all adjusters are hexes...some are square and will lead to a different "flat" count.
The SE EZ Installs are an example of a 4 flat adjuster.
Old May 7, 2007 | 10:13 AM
AMRAAM's Avatar
AMRAAM
Thanks for all the help. I will pull the PR and measure the pitch of the thread looks like 32TPI
Found some additionalhelp here on the; Tech Fourm/engines/adj push rods.
AllenW
11
Apr 23, 2013 08:33 AM
tujo33
EVO
Nov 21, 2010 09:17 AM
cthowards
Feb 6, 2010 08:51 AM
flhtupser
Mar 23, 2009 06:29 AM
95CHUCK
May 2, 2008 11:40 PM
