Screamin Eagle Pipes
Old Jan 20, 2016 | 07:58 AM
Ultraclassic Lou's Avatar
Ultraclassic Lou
4th Gear
Default Screamin Eagle Pipes
Just bought a 2005 Heritage with Screamin Eagle mufflers. They are louder than I would like. Did a DB test and it showed 87 to 89 at idle. Any Idea on how to drop it to something tolerable. I have been told to insert a stainless steel pot scrubber into the inlet side. Any ideas would help
Old Jan 20, 2016 | 11:24 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Earplugs.
Old Jan 20, 2016 | 11:51 AM
nevil's Avatar
nevil
Do they have the baffles? Some owners take them out.
Old Jan 20, 2016 | 03:13 PM
Ultraclassic Lou
4th Gear
No baffles
Old Jan 20, 2016 | 03:36 PM
nevil's Avatar
nevil
That's the problem. You can look for a set of baffles someone took off to make their pipes louder. Might even find some here in the for sale section.
You can also look into the Thunder Torque inserts sold by DK Customs. I have no personal experience with them but they seem to be used by a few of the members here who really like them. And they're not pricey.
http://www.dkcustomproducts.com/Thun...nserts_c57.htm
Old Jan 20, 2016 | 05:19 PM
OldEnuf2NoBtr
www.bigcitythunder.com
Old Jan 20, 2016 | 06:58 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
The DK Custom Products Thunder Torque Inserts were designed to increase low and mid range torque and improve the sound of the pipes by reducing engine pumping losses and increase exhaust gas velocity and scavenging.
There are two models of TTI's available, the 'W' model and the 'Q' model which can be used either with or without baffles. With the 'Q' model installed you will get less sound volume, especially at cruising RPM and under throttle. With the patented 'W' model you'll have a deeper sound through the RPM range and under throttle; the 'W' model will also provide an increase in torque over the 'Q' model.
My experience with the 'W' model TTI is they don't make the pipes actually louder but rather deeper. They remove the bright brassy tones and leave a deeper resonance.
You can read additional information along with videos on the Thunder Torque Inserts HERE
You can see fitment information on the TTI's HERE
This video might give you some idea of the tonal changes to the exhaust with the Thunder Torque Inserts.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old Jan 21, 2016 | 03:50 PM
roussfam's Avatar
roussfam
Do a search for motorcycle exhaust lollypops if you have access to a welder and are mechanically inclined....DIY version of Thunder Torque Inserts....or just buy them, can't go wrong for the price.
Jim
amer28
Mar 18, 2010 11:46 AM
finalfury
Jul 1, 2009 09:38 AM
paolu79
Apr 11, 2009 05:15 AM
kentuckydave
Mar 26, 2008 09:57 PM
scrawfordFLSTC
Jul 8, 2006 04:03 PM
