Engine Noise
Old Jun 8, 2007 | 11:54 PM
IC1SS/RET's Avatar
IC1SS/RET
Stage II
Default Engine Noise
I have a 2003 Road King Classic I bought new, and now has 27000 miles. I have developed a tap or knock noise from the front of the engine. It sounds like a tappet or loose rod. It’s not notisable at idle but is distinctive under load and gets worse after the oil gets hot. I took it to two dealerships and was told that it was the cam chain tensioners, but after removing the cam plate everything seems normal. I’m at a loss to figure this one out.
Old Jun 9, 2007 | 10:59 AM
Doc 1's Avatar
Doc 1
Default RE: Engine Noise
Did you look at both tensioners? 03 had a problem wth the compensator nut loosing up which will give you a GOOD and LOUD knock as the flywheels are aloud to move more freely sid to side in the crankcase.
If it was a cam chain tensioner and a comp nut I'd think it would make the noiseall the time, so it's possibe it is a lifter tapping.
Old Jun 9, 2007 | 11:51 AM
IC1SS/RET's Avatar
IC1SS/RET
Stage II
I did look at both tensioners, I removed the cam plata and assembly. I had also wondered about a the lifters, is there a check I could preform?
Old Jun 9, 2007 | 01:28 PM
xxxflhrci's Avatar
xxxflhrci
While I had it apart, I would have put in new lifters. They are cheap. You can get HD lifters for about 120 bucks a set or use Chevy small block lifters. I use the later. If you need it, the part number for Crane is 10530. I bought 16 for 199 shipped, put 4 in my bike and sold the other 12 to guys doing builds for 50 bucks per 4, so I ended up with 50 bucks in my lifters.
auburn08
Engine Mechanical Topics
Aug 22, 2015 06:49 PM
Hondo65
Jun 14, 2012 10:32 AM
Herbg
13
Jun 3, 2012 10:35 AM
rking2000
Sep 22, 2011 10:51 AM
genedjr
Jul 30, 2007 10:19 PM
