95" dyno
Old Jun 15, 2007 | 11:02 PM
tiiiim2's Avatar
tiiiim2
Default 95" dyno
deweys heads ,9.8 compression,andrews 37g cam, SERT, se flat tops, adj pushrods, 06 softail D&D fatcat exhaust
[IMG]local://upfiles/20388/D074A3E70E3C4ACF933130341BEE059B.jpg[/IMG]
Old Jun 15, 2007 | 11:14 PM
amstaffs's Avatar
amstaffs
Default RE: 95" dyno
Have you thought about a biger thottle body and intake ?
Old Jun 15, 2007 | 11:33 PM
tiiiim2's Avatar
tiiiim2
no, why?????
Old Jun 16, 2007 | 12:17 AM
DR.Greenthumb's Avatar
DR.Greenthumb
Good #'s
Old Jun 16, 2007 | 09:42 AM
maineultraclassic's Avatar
maineultraclassic
What gear is that run?
A 4th gear SAE run is preferred for easier comparison to others with similar builds.
The torque looks a little low for that build, I would have expected it to be up around 100 with that CR, Cams, and exhaust.
The HP looks good..........peaking at 98 is good power for the top end.
Steve
Old Jun 16, 2007 | 09:49 AM
tiiiim2's Avatar
tiiiim2
4th gear run my thoughts exactly with the torque numbers being low not sure why
Old Jun 16, 2007 | 11:21 AM
Swine Psycles's Avatar
Swine Psycles
is smoothing 5 the standard
i would like to see this chart at smoothing 3 for a better idea
also shouldn't see such a dip with fatcat is this a comp baffle?
overall nice but I have to say that a smoother tune can be achieved but don't expect any bigger glory number with what you have it is nice
Old Jun 16, 2007 | 08:21 PM
cdem02's Avatar
cdem02
I have a very similar build with close numbers. Differences are, I have the propipe, and a thundermax. My pulls were SAE so from what I've read our HP is probably within 1 or 2.
Old Jun 17, 2007 | 01:54 AM
sncstone's Avatar
sncstone
Stage III
I had the local harley shop do a 95 kit last winter on my 2006 Road King Custom. All Harley parts, gets me 104 lbs torque and 107 hp. I did get rid of the V&H pipes after a couple low runs. Went with the Bassani 2 into 1 and those are the numbers.
Old Jun 17, 2007 | 03:11 PM
Dirtrace95's Avatar
Dirtrace95
I think you need to sort out the tune up alittle more, Im talking more than just fuel curves too. I think there is more there that your just not getting.
I spend alot of time on the dyno pocking at things and always find more.
