Crankcase whining!! HELP!
Old Jun 21, 2007 | 05:17 PM
gujo0001's Avatar
gujo0001
Stage III
Default Crankcase whining!! HELP!
When my RK warms up I notice a whining sound coming from near crank. I thought it might have been the tranny (or maybe clutch), but not sure. It seems that when I am riding, whenever I pull in the clutch lever the whining stops. It is almost a squeeking whining sound. Anyone have any idea what this could be? Crank bearings? Any help would be great! Thanks!
Old Jun 21, 2007 | 05:22 PM
Swine Psycles's Avatar
Swine Psycles
Default RE: Crankcase whining!! HELP!
sounds like a tight primary chain or possible loose compensator nut to me
thanks
Old Jun 21, 2007 | 05:52 PM
Doc 1's Avatar
Doc 1
What year RK ? When you pull in and the noise goes away is it in gear or in netural?
Old Jun 21, 2007 | 10:31 PM
gujo0001's Avatar
gujo0001
Stage III
Thanks Swine Psycles. I will check it.
It is a 2001. It is in gear when I hear this noise.
Old Jun 21, 2007 | 10:47 PM
Doc 1's Avatar
Doc 1
Its hard to diagnose a noise with out hearing it but the only thing that changes from clutch engaged to clutch disengaged is the main shaft bearing in the inner primary.
Old Jun 22, 2007 | 08:49 AM
gujo0001's Avatar
gujo0001
Stage III
Thanks, Doc! I will get that checked out.
Old Jun 22, 2007 | 09:11 AM
Doc 1's Avatar
Doc 1
Another thought is when you pull the clutch in your unloading the trany and rear wheel...there is another area to look at.
yuandp
14
Jul 3, 2014 05:44 AM
Captain Smooth
May 20, 2012 04:11 PM
unfknblvbl
Dec 21, 2011 04:27 PM
Traceman
Sep 13, 2009 06:03 AM
KBES BAGGER
Oct 15, 2005 01:36 PM
