95 inch kit
forged pistons
performance a/c
andrews 26, 31, or 37 gear drive set up based on model of bike
stage I heads to take advantage of the bore and cam
Exhaust system keep it mild slip on's or 2-1 style pipe like V&H pro pipe
This set up will net you great low end gains with peak number in the 90/90 range approx
98 inch kit( bolt on no case mods needed)
stage I heads
performance a/c
exhaust = see above
this kit flat out rocks and will produce some of the best low end tw numbers on the planet
net numbers are 105-110 tq
and 95+ hp This kit make almost 100 tq at 2500!!!!!!
SPorty
slip ons or thunder header
carb kit- a/c kit
WIll really wake up a sporty
The next kit is a 1250 bolt on kit
and stage I heads
with above mods as well
I get the kits from revolution and offer it at a discount. The kit is a bolt on and can be used entirly by itself of with cam , or with cams and head work. It is offer in several compression ratios. from 9.5, 9.7. 10.1 and 10.5. The basic kit is 9.7 and 10.5 the other ratios are acheived by head gasket selection.
The kit is new cylinders, forged pistons and head gaskets. It can be used with stock or after market heads. stock cams or performance cams. SO the kit is very versital . Drop me a line if you need more info.
