Big Sucker with Stock Oval Cover?
Old Jun 26, 2007 | 07:01 PM
twilliams's Avatar
twilliams
Default Big Sucker with Stock Oval Cover?
I just put my big sucker stage 1 on last night and when I put the stock oval cover on I noticed that there was about a 1/4 gap between the back of the cover and the mounting hole. Do you tighten the screw down until it stops? won't this "cave in" the center of the cover? Right now I have it tightned so it won't move but I am afraid constant vibration with make it loose.
Old Jun 26, 2007 | 07:15 PM
dagnabit9's Avatar
dagnabit9
Default RE: Big Sucker with Stock Oval Cover?
Isn't there a bracket that went on the stock air cleaner for the cover? I'm thinking you might need to do that - I'm about to put my Stage I on too and thought I might have to use that so I made a mental note. Just something to consider...
Old Jun 26, 2007 | 07:48 PM
twilliams's Avatar
twilliams
I just took it apart and looked at that bracket you were talking about, even if it would fit it would leave a hole in the center of the big sucker filter. I stuck a couple of washers behind it for now but I still don't think its right.
Old Jun 26, 2007 | 07:53 PM
Jman67's Avatar
Jman67
My stage II kit came with a urethane washer that was about 1/4 of an inch....Did you have any left-over parts? If you need it I can send it to you. The stock cover doesnt fit the stage 2.
Old Jun 27, 2007 | 06:51 PM
twilliams's Avatar
twilliams
Jman, thanks for the offer but I think I got it worked out. I had three washers behind it and took one out now it fits pretty good.
Old Jun 27, 2007 | 09:25 PM
murphdog's Avatar
murphdog
twilliams, my big sucker was the same way. I stuck a couple washers behind the cover with some adhesive.
WnyRogo
Jun 22, 2012 09:22 AM
jackets
Mar 26, 2012 04:41 PM
Scouser1
Nov 7, 2011 07:23 AM
jeffer60
Aug 19, 2007 09:17 AM
troubletrain
Jul 27, 2007 07:31 AM
