Ness Big Sucker
Old Nov 7, 2011 | 03:00 AM
Scouser1's Avatar
Scouser1
Default Ness Big Sucker
Hi
I have just fitted a Ness aircleaner to my 06 Dyna not a problem to fit but mine is the one where you keep the original cover, is it right that the cover is just held in place by the one holding bolt in the middle?
It can move if leaned on ect?
Scouser
Old Nov 7, 2011 | 07:23 AM
northeastconfederate's Avatar
Yes, that's how the cover is mounted. I have the "Stage II" version, which has the larger element, and it does NOT like the stock cover. I replaced the stock cover with a round one becuase the oblong stock cover was very unstable with this setup and stressed the mounting plate on the Ness element. In fact, I had a strange noise at certain RPM that I finally realized was the cover being shook by vibration. It actually cracked the mounting plate. I found that a stock Evo cover fits it pretty well. I forget if I had to make a spacer to fit between it and the element's mounting plate, but it's solid, doesn't move around., and was cheap.
luvtoride
Feb 10, 2010 03:38 AM
flat train
Mar 29, 2009 07:21 AM
96 Wide Glide
Feb 6, 2008 08:40 PM
jeffer60
Aug 19, 2007 09:17 AM
wasp
Nov 25, 2006 01:10 PM
