Shift pop
Old Jul 21, 2020 | 07:17 PM
Marqu3ll's Avatar
Marqu3ll
6th Gear
Default Shift pop
Have a 2013 street glide, Boneshaker slip ons, decat headpipe, screamin eagle ventilator, and a fp3. Almost every time I shift I get one pop, sometime loud sometime quiet all different rpms. Have went back and forth with vance and hines Installed multiple tunes, changed exhaust gaskets checked for leaks still does it. Is it just how it is or do I have an issue? Thanks in advance any help will be appreciated
Old Jul 22, 2020 | 01:17 AM
kojak's Avatar
kojak
Some decel pop is common with aftermarket pipes. Sounds like you could have a tuning issue though if it’s happening as much as you said, assuming there are no exhaust leaks.
Old Jul 22, 2020 | 05:17 PM
60Gunner's Avatar
60Gunner
Some decel pop is not only common, if it doesn't happen you're most likely running too much fuel.
Old Jul 22, 2020 | 06:13 PM
Marqu3ll's Avatar
Marqu3ll
6th Gear
Yea I have a little decel pop when slowing down, the pop I have when upshifting is what I’m trying to figure out. When I roll off the throttle to up shift I get one pop. Thanks for the replies
Old Jul 22, 2020 | 07:42 PM
Coverdog's Avatar
Coverdog
Did you check for leaks at the header pipe and muffler connection?
Old Jul 22, 2020 | 08:14 PM
Marqu3ll's Avatar
Marqu3ll
6th Gear
Yea, went ahead and replaced port and crossover gaskets just to make sure with new clamp
Old Jul 22, 2020 | 08:41 PM
GregGillette's Avatar
GregGillette
There is a decel enleanment setting in the fp3 that can be tweaked which may help. Prior to picking newly added exhaust options when I had a stage 1 with the fp3, I messed with those settings and it helped some
Old Jul 22, 2020 | 09:01 PM
Marqu3ll's Avatar
Marqu3ll
6th Gear
Ok thanks for the info, do you happen to remember if you added or subtracted from the number
Old Jul 22, 2020 | 10:11 PM
GregGillette
https://www.hdforums.com/forum/the-d...eanment-2.html
forever_lost
May 6, 2015 07:47 AM
big-gun
Sep 7, 2014 09:59 PM
luckyc1423
Mar 22, 2014 02:54 PM
Sporty-ROL
Apr 29, 2012 08:14 AM
Canjojohn
Apr 17, 2007 12:21 AM
