help with build decision
Old Aug 27, 2007 | 10:17 AM
Valk1's Avatar
Valk1
Stage IV
Default help with build decision
My first plan was a very basic build, 95", SE flat top pistons, Andrews 26G and .030 gasket. Now I am thinking about 95", 10:0 compression, Woods TW6G, and a mild street port job on the heads. The difference in builds is about $800.00, will the results of the 2nd build justify the xtra cost. Bike is an injected Heritage Classic, Stage 1(SE shotgun exhaust and K&N AC). Not concerned with big HP or high RPM preformance, looking for torque early and thru mid range. Any opinions??
Old Aug 27, 2007 | 01:16 PM
JLOCKHART29's Avatar
JLOCKHART29
Default RE: help with build decision
Have never delt with Woods cams (although they are good from what I hear) but can tell you that the head work will be well worth it. The 10:1 will just help hold up your bottom rpm even more. This summer I took a set of 204's out of a partners 95inch and put in a set of 26 chains with ported heads. The grin factor was instant and the dyno proved it. Just be sure to use a porter you trust and has a good rep. By the way this bike was a Heritage carbed.
[IMG]local://upfiles/1355/276D6333A8B84810B4C6F4EB575C9921.jpg[/IMG]
Old Aug 27, 2007 | 06:19 PM
BVBOB's Avatar
BVBOB
I built my 07 Ultra to 103using the following
SE pistons bought at sale price Local Hd dealer 109.00
Sent out jugs and heads to Bigboyz for boring , porting, surfacing, ccing, 624.00 shipping and head gasketsincluded
Woods 7H cams from GMR 359.00
timken inner cam bearings 12.00
SE springs and retainers 100 bucks, (caught dealer on a good day)
Miscelllaneous gaskets 75 bucks?
retained stock pushrods
10 to1 compression low 190's ccp.
If your build does indeed come to 800 dollars more, that's not much more than the price of a good pipe. You could save some bucks by going with Andrews 37 cams at 9.6 to 1 with a Good street port (BigBoyz) and SE cast flat tops, this combo makes very good toruque and retains excellent reliability.
Old Aug 27, 2007 | 07:59 PM
mentor70's Avatar
mentor70
Well, my friend your going to get bitten by the power bug, no matter what!
Fact is, if you heads are ported properly and the right cam and compresion are combined you will have a bike that will pull like an elephant down low starting around 2200 rpmand rev hard to 5500 to 6k. this is the beauty of the T/C engine!
A 10 to 1 engine is where id start, and if you do your heads get hi lift cams with around 240 deg. intake duration and valve springs to match, it will run like a scalded rabbit! and have a very broad power band.
Old Aug 28, 2007 | 11:45 AM
04RoadKing's Avatar
04RoadKing
Don't count out Head-Quarters You might want to give then a shout. I'm glad I did. Even though the others are very good to. But I'm sold on HQ..........................
Old Aug 28, 2007 | 03:45 PM
al704's Avatar
al704
I struggled with my build decision for several months, finally decided on a build very much like your second choice. Hillside will be doing my build using the Woods 6G late in September, I'll post dyno results when I have them.
Old Aug 28, 2007 | 05:43 PM
fishafly's Avatar
fishafly
ORIGINAL: 04RoadKing
What did you end up gettin from HQ?? I've been thinkin about callin them myself... Keep readin good things... I wanna do a 98" with the 0039's I think... Did they do head work for you too?? Thanks..
Old Aug 28, 2007 | 07:22 PM
cwilks's Avatar
cwilks
ORIGINAL: al704
You'll be VERY happy with their work...Scott's a great guy..tell him Clif says yo
Old Aug 28, 2007 | 11:24 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: fishafly
Last winter I swapped out my S&S 510G'sfor the HQ-0039G's I already had the 95" 10.5:1 Wiseco with Basiely Heads. The HQ cams made A Big Big seat of the pants inprovement. If I was to send the heads off again I'd send them to Doug at Head-Quarters. InfactI have a pair of stock TC heads just sitting in the garage ready for Doug to do his magic. If I didn't have another Kid in the oven I'd be sending them to Doug tomorrow.
Old Aug 29, 2007 | 12:16 AM
mentor70's Avatar
mentor70
ORIGINAL: fishafly
Fishafly, Your bike soooo needs a HQ build, man thats a nice rig!
I have the HQ 95 sport/touring setup with the .575 Fire Storm cams, what a stump puller!
starts at 2200 rpm and pulls until I *****en out of the throttle!
