Flames out of exhaust
Old Aug 27, 2007 | 06:57 PM
valor1967's Avatar
valor1967
Stage III
Default Flames out of exhaust
Hi, wondering if anybody could help me on this,i have flames shooting out my rear exhaust what is causing this and how do i fix it?
Thanks
Old Aug 27, 2007 | 07:05 PM
Mrkicks's Avatar
Mrkicks
Default RE: Flames out of exhaust
You're burning up excess fuel, sounds like you need to have your engine remapped. Have you changed out your pipes or air cleaner?
Old Aug 27, 2007 | 07:24 PM
Softy's Avatar
Softy
It's unburned fuel. It gets past the cylinder walls and ignites in the pipes. It's not good,because it will wash away your oil on the cylinder walls,leading to engine breakdown. You need to find out what is causing it to run so rich,and correct it. Hope this helps.
Old Aug 27, 2007 | 07:34 PM
valor1967's Avatar
valor1967
Stage III
Just had the motor rebuilt,screaming eagle heads,se adjustable pushrods,se 10 :5.1high compression pistons,s&s 561 cam,se ignition module,all was fine now out of the blue i have valve train noise and the flames coming out of thepipes,when this work was done the bike was dyno tuned and everything was fine now problems.Also have an s&s carb which was rejetted during this process with v&h short shot pipes.
Old Aug 27, 2007 | 07:39 PM
Mrkicks's Avatar
Mrkicks
Just out of curiosity, do you have compression release buttons?
Old Aug 27, 2007 | 07:42 PM
valor1967's Avatar
valor1967
Stage III
No i dont have compression releases would this matter with what i have.
Old Aug 27, 2007 | 07:45 PM
Mrkicks's Avatar
Mrkicks
Not a tech here, but I know I have them on mine and I have a similar build. Been riding all season since the upgrade and no problems, maybe a rare backfire pop when I downshit from 3rd to 2nd, but it is rare.
Old Aug 28, 2007 | 09:32 AM
pauletich's Avatar
pauletich
Need to have it re-tuned and the air fuel mix adjusted.
Old Aug 30, 2007 | 09:52 AM
NCCopBikeRider's Avatar
NCCopBikeRider
As already stated, the flames are from excess fuel in the pipes. We see it every weekend at the SHort Tracks, when the driver backs off the throttle abruptly. Raw fuwl is unburned in the cylinder, but will iginite in the pipes.
You may want to remap the ECM, or get a Fuel management system
Ride Em Carry Em
Old Aug 30, 2007 | 02:16 PM
ken thompson's Avatar
ken thompson
The Schlong Man
That sounds cool. How can I get mine to do that?
