adjusting screaming eagle pushrods
Old Nov 7, 2007 | 09:26 AM
gooberhd1's Avatar
gooberhd1
Default adjusting screaming eagle pushrods
The instructions say tighten 2 1/2 turns is this too much
Old Nov 7, 2007 | 09:35 AM
gooberhd1's Avatar
gooberhd1
Default RE: adjusting screaming eagle pushrods
How bad will the engine run if the timing gears are off one tooth?
Old Nov 7, 2007 | 09:36 AM
JLOCKHART29's Avatar
JLOCKHART29
Nope, 2 1/2 turns after slack is taken out. Just make sure the lifter is fully pumped up when you start your turns. I put a drop of white out on the flat of adjuster to be able to keep track of turn. Rod should spin freely then just stop if lifter is pumped up. No steading loading up.
TheOrg
Oct 28, 2023 02:22 PM
Sparra
Engine Mechanical Topics
Aug 16, 2018 12:08 AM
asahi1234
Jan 30, 2011 03:59 PM
wadejesu
Dec 23, 2007 02:21 PM
gamb
Oct 3, 2007 06:13 PM
