Having your stock heads ported rather than porting the SE or S&S heads means leaving 8 - 12 hp on the table EVERYTIME. If you have the dough, buy the SE Hi-Per heads from Zanotti's and have 'em hand ported.
I've outgrown the thought of needing the SE[sm=bling.gif] on the side of the parts I put on my bike. I spend my money on matched cominations from people that have a proven track record. Kind of sad that one has to buy a head that says SE and then start throwing money at it to maybe get it up to the same caliber as a stock head ported by someone that knows what their doing. Like someone else mentioned.... Crack kills.[sm=icon_rock.gif]
Hear we go. 1st I have the SE preformance heads WITH the SE emblem on them and could give a rats a** if its there or not. I got them because they go with a proven build that did exactly like it was supposed to do. I got the S&S cams cause the chain drive cams in my case are not the best. I get tired of every one beating on the SE parts regardless. I keep out of these things most of the time but enough. Some of the SE parts are crap some arn't. Some are in a certain situation and not in others. Just like a part from X company is better than SE in this situation and SE is better in another application. When I got my SE heads they were about 600 or less from Zanotti. Sell stock heads and not much more than or less than porting own heads and have everything bigger and new. They work in my situation. I have done builds with stock ported heads and they do good. I will probably get my SE heads reworked but I expect it to cost more than a simple port job and I expect it to show. Bottom line is like msocko3 said "have a proven track record" regardless of who or what it is. Just had to say.
This does get confusing. I was considering a build based on stock heads ported and a medley of parts from various suppliers. I do 99% of my riding in the 2,000-5,000 rpm range. The kit I am now looking at is the basic 103(not the street legal)for a stock 96" motor that calls for SE TC Perf. Heads, Flat Top Pistons and the SE-258 cams. This is the first graph in the EFI, racing, 103 section. This kit shows over 90 TQ @2,500 and about 108TQ @ 4,000 and 100HP@ 5,200 rpm.The graph looks real strong to 5,500 rpm. It doesn't have the big numbers at the very top of scale that the custom and more involved SE builds have. This seems like a safe, relatively inexpensive way to go with "out of the box" stuff that I can get at least 20% off. My friends and I have had great results with these SE kit in the past. I believe the SERT has 2 tunes for this kit depending on pipes.
Here is one thought on why he is saying the SE heads make more power. The SE heads come with bigger valves so if your porter does not change out to bigger valves then he is correct that with the right build the reworked SE heads will make more power(depending on build of course mild builds don't need bigger valves). That said most porters that are doing heads for monster builds are most certainly going to put in bigger valves. If they don't time to find a new porter.
I don't put much stock in the little dyno charts HD shows in the SE catalog. Based on your riding RPM range I'd give Doug at Head Quarters a call, bet he opens your eyes. Or you could drop on by http://www.head-quarters-usa.comand piece together a build. I have a little 95" Head Quarters build with a so so tune making about 100ft/lbs at 2500 rpm.
msock03: If you look at the HD SE dyno charts, the torque curves look like a mountain with a slope up and a fast slope down; good 95" and 103" torque curves rise fast and stay flat (at 100+ tq) until 5K rpm or so. That's one of the reasons that a peak number is virtually irrelevant (to me), especially with torque. Also, I wonder how many dyno runs and how much tuning the MOCO put into the build to get the numbers they show.
You would get better performance (with no loss of reliability), especially in the heads, with Head-Quarters, for example, than the SE stuff that costs as much or more. Also, with an HQ package, you get a SERT or PCIII map to load for your build so you can ride following installation.
I'm not knocking the SE stuff; they serve a large segment of the market whobuy for reasons personal to them.
Whatever you decide on, let us know how it turns out for you.
Thats why I never put much stock in the chart they show with the SE stuff. Once upon a time when I didn't know any better I almost did a all SE build, I decided to spend some time figuring out exactly what I wanted and who could provide that. I already had a 95" 37g build that I didn't much care for and was left wanting more. I talked with Doug at HQ and Phill was kind enough to answer some of my questions also. Now I have a HQ touring build that does exactly what I want and more. I just wish I would have done it in the 1st place instead of the 95" 37g build.
