oil pump #
Old Jan 1, 2008 | 03:04 PM
LKHA's Avatar
LKHA
Default oil pump #
Does anybody know the HD # of the upgrade oil pump I hav a 00 UC ben told to change to a upgraded one id this just the one for the 07-08 twins? thanks again
Old Jan 1, 2008 | 03:25 PM
dawg's Avatar
dawg
Default RE: oil pump #
26037-06 retail $184.00 or $147.20 from a 20% dealer. This is the oil pump that is in the 06 dynas and 07/08 models. Also comes as part of 25283-07 which is the new SE cam plate and hi flow oil pump kit that sells for $429.95.
Old Jan 1, 2008 | 04:12 PM
LKHA's Avatar
LKHA
big difference my stealer wants 300+ Zanotti gets 119.00 just not right
Old Jan 2, 2008 | 04:47 PM
LKHA's Avatar
LKHA
Just want to verify that the pump will fit in a 00 altra classic 2 dealears have told me I need the 26035-99b that sells for around 340.00 thanks again
ORIGINAL: dawg
Old Jan 2, 2008 | 05:47 PM
duke76's Avatar
duke76
I am putting the new style pump in my 05 but am also replacing the cam plate and switching to the new style tensioners with the roller chain, If you are stuck buying the 340 dollar oil pump you may want to consider upgrading to the Andrews Roller conversion, Looks like you will be over half way there with the cost and then you will have the better tensioner setup and better oil pump setup
Old Jan 2, 2008 | 05:54 PM
Sleeps In Trees's Avatar
Sleeps In Trees
P/N # 26037-06is not a direct replacement for your oil pump w/out other modifications. Hmmm...is this deja' vue all over again?
VicW.
Old Jan 2, 2008 | 06:10 PM
dawg's Avatar
dawg
ORIGINAL: Sleeps In Trees
VicW.
ORIGINAL: LKHA
If you were to do the conversion with the newer plate, etc. you could use this pump. Have you considered do the roller chain conversion?
Old Jan 2, 2008 | 06:47 PM
LKHA's Avatar
LKHA
Thanks guys will stay with origianl pump was just going to change while I was there. back to trplacing the oginsl style tensioners if I can find a cheap cam might slip it in as I have bought a tunner and AC and have the pipes thanks again
Old Jan 2, 2008 | 09:47 PM
duke76's Avatar
duke76
If you are going to install a cam you just as well do the conversion, with 340 for the oil pump and 250 for the cams you can do the whole Andrew Roller Conversion
http://cgi.ebay.com/ebaymotors/ANDRE...spagenameZWDVW
You can probably even get it cheaper from Zanottis, The above link has evrything you should need including cams
soft 02
Feb 22, 2011 04:09 AM
rbabos
Aug 5, 2008 03:40 PM
kelton3
Jul 15, 2008 06:30 PM
darkdyna06
May 7, 2008 12:07 AM
Arvid
Oil Archive (no new posts)
Jun 26, 2007 11:31 PM
