base gasket
Old Jan 27, 2008 | 08:15 PM
snod's Avatar
snod
Default base gasket
Hey guys can you pull the heads of of a 96 ci.with out pulling the jugs as far as base gasket leaking go,s?
Old Jan 28, 2008 | 05:32 PM
Old Gunny's Avatar
Old Gunny
Default RE: base gasket
Since they use ,"O" rings, no. Having said that Hi temp silicone could be used I bet. Doesn't really use a gasket otherwise.
Old Jan 28, 2008 | 05:49 PM
msocko3's Avatar
msocko3
If you don't disturb the jug then you should be able to swap heads with no problems. If your going to turn the engine over with the head off I would make sure there was something holding the jug down. They make nuts for this and I've seen others use the head bolts and some PVC pipe as spacers to do the same thing.
Old Jan 28, 2008 | 06:20 PM
dawg's Avatar
dawg
ORIGINAL: snod
Base gasket or head gasket????
You can pull the heads and replace head gasket without pulling the jugs, base gasket o-ring you cannot.
Old Jan 28, 2008 | 07:12 PM
snod's Avatar
snod
Yeah I was just wanting to pull the heads and do A Big Boyz job and didnt want to pull the jugs.Im useing the 37 cams with stock heads and pullin 81 h&92flb just want A little more.Thanx guys.
Old Jan 28, 2008 | 07:19 PM
dawg's Avatar
dawg
ORIGINAL: snod
Cometic .030's
Old Jan 28, 2008 | 07:44 PM
snod's Avatar
snod
Hmm. what would just the 030 head gasket Do?
Old Jan 28, 2008 | 08:14 PM
dawg's Avatar
dawg
ORIGINAL: snod
bump up the compression a tad for your cam.
Old Jan 28, 2008 | 08:35 PM
snod's Avatar
snod
Thanx Dawg...
cvaria
Engine Mechanical Topics
Aug 23, 2018 02:00 PM
QNman
Aug 22, 2017 11:35 AM
borncountry
Jun 1, 2012 09:26 PM
speakerfritz
Oct 5, 2011 06:25 PM
jakazz
Jul 2, 2007 10:05 AM
