As Steve has mentioned, the additional cubes come from the stroke.
It is a very straightfoward way to increased torque, and has been done for many, many, years in the performance market, as S&S was contracted by Harley to develop the 80" Shovel, from it's smaller counterpart, the 74" engine.
Also on the 96", the heads seem to be a better casting than the 05's and earlier 88" powerplants.
The 6th gear, is without a doubt a worthless addition, as the OEM engine cannot pull it.
Once you step it up to a good, strong, torquey, 103", or more,then that gear actually becomes useful.
So to answer your question, the 96" set-up is a better mousetrap.
Which 88??? The '06 has the best heads of the 88's, and a larger EFI throttle body which are pluses for engine mods. The '05 88 head hasa valve seal issue that the MOCO had to fix for customers.
The 96, because of the4.375" crank makes muchbetter torque, especially with bolt in cams, than the 88, but also has negative deck height due to HD's use of a slightly shorter rod andthe crank may be a weak link if you want a high compression and/or larger displacement build.
If you wanted to do a 110" or larger performance motor, then there isn't much difference because you end up changing pretty much everything in the motor anyway.
I wouldn't say the 6th gear was useless, maybe for most riders it is just not practical, for long interstate riding it will work great even in a stock bike, but hell, who wants a stock bike anyway. As for the original question, it's like asking if the 350 or 400 Chevy is better, each has its advantages but in the end, all else being equal, cubic inches always wins the HP/torque war, whether it's done through bigger stroke, bigger bore, or both. Now, if you are speaking of reliability, both the 88 and the 96 each have been known to have strengths and weaknesses all their own.
have n't riddin 96 ci.I agree the bigger crank makes for good start to more power. extra stroke always gives more torque.ad bigger pistons,bigger cams, bigger heads,bigger throttle body and new exhaust then your ready to stretch that 6th gear out.
I did not mis-spell. Watch closely again. #6 gear in a bonestock bike, 2-up,could not pull a baby carriage down the road, correctly.
Not justfloat down the interstate,(a moped is capable of that)HOPING that you won't encounter a grade of any kind, then need to downshift, while mom and the kids wax you, in the hammer lane, in their Kia.
I'm talking about aMAN'S motorcycle. The kind we are used to building at our shop. Thanks for your concern in regards to our health, Mr. Voodoo.
