Had it dynoed today.
Old Mar 3, 2008 | 06:13 PM
Tn.Heritage's Avatar
Tn.Heritage
Default Had it dynoed today.
Well needless to say I was dissapointed in the turn out, I don't have a scanner but I will be honest with ya, here's the #'s, 75hp and 92tq, the tuner is avery honest guy so here's what he had to say, first of all those V&H's pipes are killing you, any other pipe would have been better, your rings are not seated as of yet, the guy helping out said he heard the rings flutter, ha also said I could get 5 more hp but I didn't see any since in beating up a new engine to do that, thetq was pretty good thiough.
Old Mar 3, 2008 | 06:22 PM
PhilM's Avatar
PhilM
Default RE: Had it dynoed today.
Mark ~
How many miles do ya have on it now? I read that you recently did the ring seating runs.
Also, what compression did they set you up with?
As duals go, the V&H aren't that bad. What slip-ons do you have with them?
Carb of fuelie & how did ya tune it?
Old Mar 3, 2008 | 07:01 PM
darkdyna06's Avatar
darkdyna06
Those #s arent bad, a little low on peak horsepower, but what does the curve look like? Probably makes 90ft.lbs. all the way across which is what you really want. I had mine on the dyno again today, and was not real disapointed when it only made 84hp ( it made 87 the first time), because the torque curve is real flat. I would have gone with a bigger cam than the 203s, the 204s, or the Andrews 37s (which is whats in mine) would get you a few more ponies, and work good with stock valve sizes and modest compression.
[IMG]local://upfiles/21800/97DC6CD55F44485F9A4D611374D665BD.jpg[/IMG]
Old Mar 3, 2008 | 09:57 PM
BVBOB's Avatar
BVBOB
Heard the rings fluttering? Now that's a new one on me, sure it wasn't pinging?
Old Mar 3, 2008 | 10:29 PM
Tn.Heritage
ORIGINAL: PhilM
Mark ~
Phil I had about 50 miles or so on it and that included the ring seat ride, I have a PCIII on the bike and a set of rush mufflers with 2 1/2' baffles with 3"removed from the baffles and a set of thunder monster baffles in the end of the head pipes, could there be to much baffles, the dyno guy said I'll bet you will pick up some more horses when everthing gets seated in, the bike pulls great, I guess I should have waited until 500 miles or so.
It should have 9.4 1 compression, I have to much heads and not enough cam sort of speak.
Old Mar 4, 2008 | 12:29 AM
Tn.Heritage
I have beat my self to death over this, do you guy's think I've got to much baffling in the pipes, could that be holding it back, maybe I ought to pull the thunder monsters out, [&:]I don't know.
Old Mar 4, 2008 | 12:58 AM
mentor70's Avatar
mentor70
I dont think the pipes are holding you back.
If you have a 9.4 to one engine those #s are realistic.
I think after 500 miles the dyno #swill look alot better.
I jetted my bike too rich when I installed my 95 kit and It took over 400 miles to seat the rings!
the cranking cylinder presure went from 175 psi at 50 miles or so, to 200 lbs at 375 miles.
try it again after some seat time.
Old Mar 4, 2008 | 04:36 PM
spankustang's Avatar
spankustang
ORIGINAL: Tn.Heritage
What's wrong with the V&H true duals??
How can they be any worse then others?
Old Mar 4, 2008 | 04:44 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: spankustang
That's the point..........all duals will kill your low-end torque.
Steve
Old Mar 4, 2008 | 07:56 PM
Dogwood's Avatar
Dogwood
Are saying you or the tuner did ~6000 RPM dyno runs on a build with 50 miles on it?
