Have you had crankshaft problems on a 2007 or 2008?
Old Dec 8, 2009 | 02:18 PM
  #51
paul s's Avatar
paul s
I didn't think mine was shakin too bad, but it sure has a lot more action than my brothers Softail. I've been thinking about crankwork/Timken for a while now wondering if I would need it for a mild 9.5:1 build. I guess I know the answer, I can't see taking it down for a topend and leaving a questionable crank in there.
Old Dec 8, 2009 | 06:58 PM
  #52
car5car's Avatar
car5car
If your bike is under warranty you will win law suit w/o lawyer! The only thing you need is document from some repair shop about bad condition of your engine. Harley and Davidson both will call you and ask you to bring your bike to a dealer for engine replacement as soon as they receive court papers.
Good luck.
Call customer service first and warn them about lawsuit and then letters to all magazines.
Old Dec 9, 2009 | 11:03 AM
  #53
Kingofcubes's Avatar
Kingofcubes
A Softail "B" motor is going to be smoother. I would leave that decision for when I removed the cam plate, inspected the oil pump, and checked the pinion shaft run out. If I found these issues to be good, I would not take the bottom end down unless I was planning on exceeding 120 T&H.
Old Feb 20, 2010 | 01:59 AM
  #54
suey's Avatar
suey
my 2010 road glide crank has .006 after 1000 miles.... mechanic has seen 3 out of 4 cranks on 07 and newer more then .005 out and seen 2 cranks cause major damage, one bike had 7000 miles and the other had 18k
he did replace a crank in a 07 dyna that harley had already replaced 2 times....
im going with s&s crank adn timken setup and be done with it.... if i wait for harley, it might not go out while under warranty OR whos to say they use a good crank again?
sigh... money money money
Old Feb 20, 2010 | 06:51 AM
  #55
Dalton's Avatar
Dalton
The cranks are a crapshoot. Far more of them still running, even with HP builds than those that have come apart. That being said, I would not do any build above 107" without going into the bottom end. Up to that point, you can build 'em, ride it and watch for any tell tale signs of issues such as vibration, excess oil through breathers, oil pressure fluctuation and noise from the cam chest. Owners do not have an endless stream of money so I build 'em and tell the owners to hope for the best, that most likely they will not have issues. There is always that chance that a crank will shift, but there are thousands of modded motors out there that have not had issues with crank shift.
Old Nov 10, 2014 | 03:42 PM
  #56
pete64's Avatar
pete64
Stage IV
Default 2007 flhtp oil pump shattered
my 2007 flhtp with 18000 miles oil pump shattered .measured end play on crank and is .015 .no warranty.
Jersey Drew
Northeast Tri-State Area
Nov 1, 2014 01:20 PM
Muscle-man
Sep 21, 2012 02:27 AM
toyman57
Aug 9, 2012 05:18 PM
badinfluence63
Jan 15, 2009 05:29 PM
skifrik
Jul 7, 2008 06:06 PM
