compression calcs
Old Jul 8, 2008 | 01:20 PM
natural gasser's Avatar
natural gasser
Default compression calcs
Greetings all. New here and would like some help. Want to verify compression ratio.
Here's the plan.
113" TC in a bagger
4.065" bore
stock reworked cyl heads with&nbsp\\;89cc combustion chamber
4.375 stroke
R&amp\\;R .615 cams (47° intake close)
.030 head gasket
Flat top pistons-JE
When using a comp calculator do I list 2cc for the valve reliefs in the piston dome field?
Looking for 10.5:1 static and 9.3 or 9.4 corrected.
Am I close? Will this be a "ping monster"?
Any help greatly appreciated.
Old Jul 8, 2008 | 05:56 PM
natural gasser
Default RE: compression calcs
bump
Anyone?
Old Jul 8, 2008 | 07:56 PM
ez2cyio's Avatar
ez2cyio
www.bigboyzheadporting.com
They have the best calculators I've seen.
Steve
Old Jul 9, 2008 | 07:19 AM
natural gasser
Thanks, that is a great calculator. My numbers were very close, so with a proper tune, should not ping.
Old Jul 9, 2008 | 09:36 PM
TXCHOP's Avatar
TXCHOP
You will be fine. That cam loves 10.8 comp and it wont ping as long as the tune is in decent order!
Make sure deck height and squish is in order, get a good tune and you will never have a problem!
Old Jul 10, 2008 | 12:38 AM
Max Headflow's Avatar
Max Headflow
10.5 to 1, 47 degree intake close, good bathtub heads? CCP at 195. With the BB you should have plenty of quench.. If FI find a good tuner. Bike should run fine.
&nbsp\\;
Bruce
&nbsp\\;
DeneFXDWG
Apr 22, 2019 05:10 PM
txphatboy
20
Apr 16, 2013 07:47 AM
fireaxxe
Feb 2, 2011 06:08 AM
UltraKla$$ic
Sep 24, 2009 11:08 AM
springer1996
Feb 27, 2006 12:44 PM
