I know..another TAPPING question!
Old Jul 19, 2008 | 11:40 AM
srm148's Avatar
srm148
Default I know..another TAPPING question!
I have searched the threads on here and found some answers, opinions, what have you, But couldnt find an answer to this.... The other day at the dealership, I asked them to take a look at my bike as the ticking/tapping sound is VERY annoying. They pulled a pushrod out and it was worn a little about halfway up near the top. The mechanic said that it was hitting the hole as it goes through the head. That is my tapping sound. he recommended putting tapered rods in it. He said that would cure the sound. I do have a big bore kit with cams. Has anyone encountered this?
Old Jul 19, 2008 | 11:44 AM
Bryan TTM's Avatar
Bryan TTM
Default RE: I know..another TAPPING question!
yep....tapered will sure help....when installing them check the rocker arms on the shaft...push em back and forth and see how much play is in them....tight side of spec is .004...if you have abuncha side to side play, there's some tap as well...shim the shafts on the pushrod side with some shovelhead shaft shims....you gotta do it when you replace the pushrods so's there'll be no load on em....b
Old Jul 19, 2008 | 11:50 AM
Bluesssman's Avatar
Bluesssman
ORIGINAL: Bryan TTM
Great information!!! This is what I look for in this forum.
Old Jul 19, 2008 | 01:32 PM
srm148's Avatar
srm148
I appreciate the info. That is why I like these forums. Thanks again................
jl207299
Engine Mechanical Topics
35
Mar 13, 2024 06:30 AM
dynasnow
Sep 29, 2017 09:56 PM
MA-FXDBI-DB
Sep 11, 2017 12:34 PM
docman
Shovelhead
May 11, 2016 10:46 AM
vailtl
Aug 30, 2007 01:36 AM
