What did I do now...
Old Aug 13, 2008 | 09:23 PM
hittman's Avatar
hittman
Default What did I do now...
I installed a new set of the Bassani TD pipes with the power curve. I now have some vibration in my floorboards that was not there with the stock pipes. My brake pedal is not touching the the front pipe, however there is very little clearance between the power curve and the two transmission bolts (which I did replace with the supplied round top bolts). Do you think this is causing the vibration? Has anyone else had this problem and found the cause?
2007 FLHX
Old Aug 13, 2008 | 10:10 PM
Doc 1's Avatar
Doc 1
2007 FLHX
Changing the pipes changed the air flow of the engine drastically so you need to tune the bike by a good tuner....this will eliminate the vibration.
Txn09
Oct 4, 2013 07:12 AM
APEDnLOW
Jul 7, 2012 08:05 PM
docsking
Jun 29, 2010 09:07 PM
Burstbucker
Oct 12, 2009 06:19 AM
Pipedream
Feb 17, 2008 10:37 PM
