06 Dyna Cam Install"SE203"
Old Apr 4, 2006 | 03:18 AM
rastas's Avatar
rastas
Default 06 Dyna Cam Install"SE203"
hello all,my strretbob is booked in for tomorrow to get 25' injectors installed and SE203 cams also.The question is do they have to remove the heads to check the valve clearance between the top of piston and the valve as stated in the instructios that came with the cams.My dealer is under the impression they do not have to remove the heads.instructions say to apply clay to top of piston reassemble heads to torque and measure clearance after two engine revolutions by hand.My service manual has not arrived yet so any one with 06 dyna service manual can u check please.
Old Apr 4, 2006 | 02:24 PM
PhilM's Avatar
PhilM
Default RE: 06 Dyna Cam Install"SE203"
For "bolt-in" cams (meaning not hi-lift w/stock valve springs) clearencing the the valves with clay is unnecessary. They will not remove the heads.
Old Apr 5, 2006 | 01:18 AM
baggersport's Avatar
baggersport
Phil is correct. Instructions with the cam state the clearance check to cover their ****. Your dealer should know that he will not remove the heads to install that cam choice.
Old Apr 5, 2006 | 03:46 AM
rastas's Avatar
rastas
thanx guys.your dead right,thats what i thought,and after talking to other biker's and dealer thats what was said.CHEERS
blksoftail
Jul 15, 2011 11:30 AM
Trex
Nov 17, 2010 06:41 AM
XMA
Aug 5, 2010 07:35 PM
rastas
Apr 4, 2006 11:21 PM
bobcowan
Dec 8, 2005 07:37 AM
