I am looking at the TW6g Woods cam. I want to switch to gear drive, and have gotten good feedback on the TW6g cam for low to midrange performance. I have heard that switching to gear drive is the way to go but that crank runout could be a problem.
How do I find out what the runout is? Have a shop take it apart to check?
I am also adding a D&D Fat Cat at the same time. Philm has helped me in that department and has answered a lot of questions already. I want to go to a 95" kit in the future so I want a cam that will work with the 88" and the 95" bore sizes.
I guess I am just wanting to know if I am on the right track and if the runout issue is common?
thanks
Oh yeah, just to answer your question about what I'm looking for: I want a cam that will add torque and hp low to mid, maintains ridability and reliability and is good to build on later if I choose to go bigger bore.
The only issue will be if the runout is so extreme that it destroys the oil pump. If the crank is so far out it will put too much stress on the rotors in the pump and can cause severe wear or complete failure.
The bad part about taking it in and having it checked is that they have to take it apart to do the measuring. You don't want to pay to have it taken apart, measured, then pay to put it back together. Basically, the bike will have to sit disassembled while you are waiting for your cams to come in if your shop doesn't stock the parts you need.
Yeah, that's the delima i'm trying to get around. I don't want to pay to have the bike taken apart, and crank measured for nothing, but then I don't want to buy the gear drive cams and conversion kit and then not be able to use them.
I guess, I could wait until I am ready to order, then take the bike in, have them take it apart, measure the crank, then decide whether to go gear drive or chain based on the result. But this could lead to the bike sitting unassembled for a week or two. Anyone have any other solutions?
Also, anyone know anyone reliable in Dallas/Fort Worth who does this kind of work?
Takes about 15 min. to check the pinion runout at the point of opening the camchest area, when preparing to install the new cams.
We like to see .003 TIR maximum, for a gear driven install.
