Pushrod Clip Problem
Old Dec 17, 2008 | 03:59 PM
jslagg's Avatar
jslagg
5th Gear
Default Pushrod Clip Problem
WTF, I had no problem getting all of them off but now the rear cylinder Clips seems to be tight.....Is there something I need to do that I am just missing something?
Old Dec 17, 2008 | 06:42 PM
Old Gunny's Avatar
Old Gunny
Make sure the tubes are inserted all the way. You can catch a lip and they will seem too short.
If you do and get them in anyway you'l have a nice oil leak. More that likely while go somewhere with the better half, whick will just charm her no end.
Old Dec 17, 2008 | 07:48 PM
FXSTDSE2's Avatar
FXSTDSE2
It's been a while but I custom ground a open end wrench to use as a compression tool. After making sure the tubs are seated correctly I slip the retainer in position, slided my "tool" on and compress the spring retainer down and presto, the retainer slips in. I think its was a 3/4 cheepy Taiwan wrench.
Old Dec 18, 2008 | 07:40 AM
0lowrider1's Avatar
0lowrider1
how are you trying to put them in ? are you levering them in with a screwdriver like the service manual says ? i seen on georges garage that he sells a tool for this...thinkin bout getting one
Old Dec 18, 2008 | 12:40 PM
Old Gunny's Avatar
Old Gunny
Make sure each tube end is inserted fully into their seats against the O rings. Push the spring collor down to where it goes. Put a retainer keeper in place against it. Use about a 1/4 in. flat bladed screwdriver under the retainer and lever the clip in. As you lift up with the screwdriver push with a finger on the clip.
Generally a piece of cake.
If still a problem look at the clip and see that it has a good curve. you can curve it right with pliers.
LQQK_OUT
Aug 22, 2017 04:05 PM
LQQK_OUT
Mar 2, 2016 05:56 PM
Shawrco
Jan 23, 2013 04:01 PM
6speed
Feb 20, 2009 09:47 AM
Calwoodbutcher
Ironhead
Aug 7, 2006 03:46 PM
