Bigger Throttle Body
Stock modified heads, stock heigth cylinders.
I am leaning toward the Kuryakyn Wild Thing # 469 with #467 flanges. Mainly cause seems to be a bolt on with ability to use all HD stock type aircleaners. and price.
I would appriciate any thoughts on this whole subject, not just what I am leaning toward.
Thanks
Old Gunny
Thanks
Old Gunny
Thats the thing I need imput on. The SE big bore TB is 51.
Will it fit, bolt up?
The Zippers sounds good but you got to buy their Air filter backing plate to use theirs. For another chunk of change.
Had a Chevy with Tuned Ports (long intakes for torque) in 1990. Had speed density like our Harley's. Today same engine, sort of, with giant intakes puts out the same low or hang on high RPM.
I know with carborators there is both Air and Fuel. Have to think about volicity. With FI there is just Air. I know Air has weight but I wonder if a big TB can be tunned to keep low end?
See 72 and still wondering, never stops.
So it's 50 SE or 55-58 other brands?
And yeah those BCheads are differend.
The larger the port diamater the more you reduce port velocity, you have to find a good balance to keep velocity up without reducing overall volume.
Not sure what your talking about with the BC throttlebody but it bolts right up to the stock heads and sensors, no mods necessary.
the screamin eagle t/bs do not flow well
the 51mm horsepower inc and s.e. injectors is good for 125 or more hp on an '08 big twin
I'm very happy with my setup...mpg did suffer a lot, even after setting afr to 14/1 from 20% throttle down...and it will bog if I whack the throttle at too low rpm...throttle response improved a lot, and I gained 11 horsepower...it is a bobbed dyna and I weigh 170, so I'm not concerned about losing a few points of torque
the wood 7 is more of a torque cam...it will be interesting to see what you gain, and at what rpm
I am not selling anything, just sharing my experience/opinion
A little heads up, but dual runner TB's like the BC Gerolomy TB is actually much easier to tune. Reversion, cam/cylinder overlap etc between cylinders is now eliminated. Tuning becomes much easier when the injectors send fuel to the cylinder intended.
Skyhook, if you "whack" the throttle quick and your engine "bogs" down with a low pitched exhaust tone, its just a sign that your running too large of a throttlebody and your combustion burn is suffering from it. Your intake charge just isnt what it should be. When it comes to carbs and throttlebodies, bigger is not necessarily better, many/most times its actually worse.
